[email protected]
- Jan 1, 1970
- 0
I built a small LM386 amplifier and attached an antenna and an
envelope detector to it. For a few days i was able to listen to some
local radio through it but when i tried to power the circuit from my
ATX psu(5V), all i heard was a loud noise. It's fine while powering
from a 9V battery but when i switch to a power supply, this problem
arises. When the input is my PC's sound card, i can listen to anything
without noise, and also when i disconnect the antenna(long wire) from
the detector, the noise disappears. I have tried this with a linear
regulated supply, too. The result is the same noise.
What is causing this noise? The first think that comes to my mind is
that it is the noise from the AC line but then why it disappears when
i disconnect the antenna or when i use it as a normal AF amplifier? I
am totally confused.
What i tried;
Put an active decoupler between the circuit and psu,
used a 7805 with 100n caps on each side,
tried a linearly regulated power supply,
put a 10 uF bypassing cap between pin 7 and ground,
put two(470 uF and 100 nF) bypassing cap between the V+ pin and
ground,
moved the psu away from the circuit,
put a small 3.3 mH filtering choke between the psu and the circuit
and other countless attempts that i don't remember now. None of them
actually eliminated this loud noise.
I am waiting for your advices, thanks in advance...
What i tried;
ground,
