About this Cirucit
cyw1984
Sep 7, 2005
63
Is it OK?get any problem??
I am a newbie.....which part is current limit??
If i want to remove the current limit part...how to change the circuit?? thanks
cyw1984
Sep 7, 2005
63
I remove the current limit part....Am I right???
also.........
What is the function of the RED circle??
The diode may i repace the resistor there??
Which op amp I should use there????
thanks a lot
Staigen1
Oct 26, 2003
695
Hi
also.........
Yepp, but you also removed the current feed to the ic and it's ground! ???
The red circles you put on the schematic is for highlighting some of the components, i belive
If you omit the current limiter, wich i belive you should not, you can also remove the 1N914 diode, but you have to do something to the errors in the output pass transistors stage, as proposed in the other thread. BTW, why two threads about the same thing?
See the other thread!
thanks a lot
Be my guest
//Staigen
