AC switch with 2 mosfets
Adam Seychell
I'm looking for a simple and cheap way of driving two mosfets in
series with sources tied together. I need to convert logic signal from
a microcontroller and make it control a isolate AC switch (30 VAC 50Hz
@ 4A). Switching frequency is about 2 Hz, and will power a heater
element.
How about a 555 timer driving the a small toroid transformer at 500kHz
with secondary as shown. The reset pin of the 555 can then be used to
signal the AC witch.
1:2 |
----- 10nF |
| |----||---#|| |\| D
|555 | #||#--o--| |-o---G
| | GND---#||# | |/| | S
----- ||# | 4.7k |
||#---------o-----o
| 4.7k |
| |/| | S
--| |-o---G
|\| D
John Larkin
element.
1:2 |
----- 10nF |
| |----||---#|| |\| D
----- ||# | 4.7k |
||#---------o-----o
| 4.7k |
| |/| | S
--| |-o---G
|\| D
Photovoltaic opto-couplers are cool, too. They typically generate
maybe 9 volts DC, but are rather slow, as the output current is low.
Or a triac?
John
CBarn24050
element.
A power inverter I'm repairing has just such a device, they use a dc-dc
converter (nme1212d). If you only have 5v you could use a nme0512d instead.
W
Walter Harley
element.
The usual way of doing that is to use a solid-state relay. Any special
reason you're trying to avoid that?
W
Winfield Hill
Adam Seychell wrote...
element.
1:2 |
----- 10nF |
| |----||---#|| |\| D
----- ||# | 4.7k |
||#---------o-----o
| 4.7k |
| |/| | S
--| |-o---G
|\| D
Connect both n-channel FET gates together, and use just one diode
to rectify your 500kHz ON pulse train.
Alternate opto schemes include using a PVI1050, see IR's DT 94-5,
or an optocoupler, see their DT 94-12.
