Accel HEI Super Coil- negative secondary ground??
Bill Edwards
I have a project that involves using an Accel 140003 HEI Super Coil. The
problem I'm having is that I don't know which terminal is the high voltage
ground. This coil only has a 2 wire primary (red and yellow wires) with no
blue/black as ground in other coils, so that is what's causing the
confusion. Can anyone tell me where the high voltage ground is located?
Bill
Jamie
Bill
http://www.accel-ignition.com/pdf/140003_140005.pdf
if you scroll down, if tells you to connect the
yellow wire to the C slot which is the (-)
and Red wire to the B+, which I think is the tach signal
from the ignition.
I guess this means the (-) would be the common if you're not
using it for automotive use.
The remaining wire is the HV lead..
This is obviously a auto transformer.. What this means is, the
HV lead shares the same windings as your Red and Yellow ect, there
is no isolation. the HV lead simply has a lot more turns after the
B+ lead connects internally.
Hope that helped some.
http://webpages.charter.net/jamie_5"
