Activate a relay using laptop's parallel port
hrgwea
Apr 13, 2011
Hi, guys. I'm new here. Forgiveme if this is too newbie.
I have a relay that I want to switch on using one of the output pins on the parallel port.
This is what I've got:
The relay is powered by a 5V DC adapter and the transistor should act as a switch.
But i dont know where to connect the parallel port's ground pin.
If I just connect the 5V pin to the transistor's base (like the diagram shows), it doesn't work.
Resqueline
Jul 31, 2009
2,848
Ground to emitter/-5V. Add base resistor (value depends on port, transistor, & relay data).
