Activating a pump based on water flow
Paulo Borges
Jul 1, 2017
15
Hi, thanks, I will change my test circuit with your suggestion.
I had this problem with my test circuit, the one I mention at the first post.
I had a the sensor connected via a 1K resistor to pin 2.
I added a 0.1uF capacitor in series and it looks like it solved the problem.
Will work on the changes.
Paulo
Paulo Borges
Jul 1, 2017
15
Ak, I have combined my circuit (positive trigger) with the given circuit proposed above.
I will still use a led for now and migrate to the relay next.
Can you please take a look and see if you agree?
Paulo
Alec_t
Jul 7, 2015
3,821
Assuming you can get at least one pulse per second from the flow sensor, and that the default sensor output is 0V in the absence of flow, something like this should do the trick :
  • FlowTrigger.asc
Paulo Borges
Jul 1, 2017
15
People, thanks for your assistance, I tried both circuits and both work OK, just added a 220uF/16v capacitor at I had in my toolbox at the very entrance of the signal coming from the flux sensor and it works great with a led. I would probably have taken ages to figure it out by myself, I am just a hobbyist.
Thanks Ak and Alec_t for your time.
Keep well
Paulo.
Paulo Borges
Jul 1, 2017
15
Hi people.
At the end of the day the circuit I am using is the one shown at the attached picture. (some components replaced as per availability).
I do have a minor problem though:
When I apply power the relay is immediately activated, likely as a result of charging capacitors.
This is not a serious problem as the pump is activated by just a couple of seconds but is an imperfection that bothers me a little bit.
Have you got any suggestion?
Thanks in advance.
Alec_t
Jul 7, 2015
3,821
You could try a standard 'power-on reset' arrangement. Connect pin 4 of the 555 via a high value resistor to the +ve rail and via a fat cap to ground.
