Jim Thompson
- Jan 1, 1970
- 0
No. I'd have asked you directly, here. I didn't think it was so but
on a hunch, I checked and I found it in Hans Camenzind's 7MANUAL.PDF
p. 5-11.
<quote>
As we have noted above, the voltage gain in the bipolar transistor
is anything but linear.
Current gain (hFE), on the other hand, is a naturally linear
parameter. For this reason alone it is
easier to achieve high performance stressing current rather than
voltage amplification.
</quote>
Huh? "Stressing" as in talking about it? The linearity/nonlinearity
of the parameter of choice affects performance? What? the
performance of communicating thoughts?
Then he talks about the swing across the Miller cap - you know this
story already, but to keep things in context:
<quote>
But there is a second reason.
Each junction has a capacitance
(created by the "space-charge
region"). Of particular bother is the
collector-base capacitance. Not
that it is especially large (it isn't),
but it is badly situated. Using the
transistor as a voltage amplifier,
base and collector terminals move
in opposite directions (i.e. they are
180o out of phase). Since the
transistor is capable of a large
voltage gain (especially with a
current source load), the voltage
swing at the collector can be
several hundred to several
thousand times as large as that of the base.
</quote> ... you know the rest.
So he'd have no voltage gain at all?
He goes on with the Miller effect a bit more and then he talks about
the cascode fix for the Miller cap and here's the killer:
<quote>
The cascode stage is only a halfhearted use of current
amplification. A better approach (at least
for high-frequency performance) would be to avoid converting to a
voltage altogether.
</quote>
That's where I was left hanging. Maybe he just means that the large
swing across Mr. Miller kills the highs.
That's where slew-rate and "power-bandwidth" come into play in OpAmp
descriptions.
...Jim Thompson
