Active load circuit 5-8A
Kaminari
Aug 23, 2010
Hello.
I need an active load with current control to test my power supply (PSU is project here http://www.electronics-lab.com/projects/power/001/index.html)
I found schematic
But I contacted autor and he told me it's generally bad idea to copy becase it's not stable enough. He told me that the best way to avoid this problem is to delete IC2A and set voltage divider 1:22 on positive input of the IC2B.
But then, how would the schematic look like?
But i've got some other ideas. First of all i would like to replace voltage reference with LM317 (I've got 10 of those).
I think of replacing BC transistors by the pair of 547B/557B or 550C/560C, because i've got many of those. Is this good idea?
And finally i would like to replace FET transistor by any other I would find in ATX power supply (I've got like 50 and I think i might find some replacemant that could handle 10A.
I will of course do schematic in eagle but i need some help with this. Is there a place where I can measure voltage and calculate current limit? I think it should be close to the 5W resistor.
Thanks for the help in advance
Sorry for my mistakes, English is not my first language.
Kevin Weddle
Feb 23, 2004
1,620
You might want to test the power supply different ways. A variable high power resistor can be used test the supply under DC conditions. Then a circuit can be made to test at increasing frequency loads. Some common electronics products you generally buy can also be used to test the power supply.
