saurabh17g
- Mar 8, 2010
- 72
- Joined
- Mar 8, 2010
- Messages
- 72
I am planning to select the registers FSELECT and PSELECT using software. So what do i need to connect to the pins Fselect(pin no. 9) and pselect(pin no 10) is it DVDD or DGND or AVDD or AGND. According to pg no 7, they have mentioned that we can connect these pins to vdd or gnd. it sounds confusing.
Is it that these pins should be connected to ground through a resistance of 10k (refer the circuit diagram given on pg 29)?
Do i need to build separate power supply for AVDD and DVDD or one power supply with output of 5V is enough?
