ADC to LPT port ?
DusanS
HI..need some help.....:)
I want to connect AD converter (ADC0804) with computer via LPT port,
to collect digital data.
On input ADC is signal form microphone preamplifier, fullwave
rectifier...
ADC and rest of circuit works well, it is tested with several led
diodes.
I just need simple circuit scheme(or direct if possible) to connect
output of ADC to LPT port.
Any simple program on net that can communicate to LPT? Or I should
write some program in Visual Basic,Delphi or C(++).
Thanks...
Si Ballenger
rectifier...
diodes.
Thanks...
You may want to check the below kit. The pdf has the schematic
and there is also a link on the page for the software.
http://electronickits.com/kit/complete/data/ck2001.htm
http://electronickits.com/kit/complete/data/ck2001.pdf
Rich Grise
I want to connect AD converter (ADC0804) with computer via LPT port, to
rectifier...
ADC and rest of circuit works well, it is tested with several led diodes.
Any simple program on net that can communicate to LPT? Or I should write
There's LPT port stuff all over the internet:
http://www.google.com/search?lpt+port+interface
But why not just use the sound recorder that came with the PC?
Good Luck!
Rich
DusanS
Thanks.....
I already made a simple circuit and a simple Visual Basic monitoring
program.
I could do it directly connecting to data pins, but to be extra safe I
used scheme found (somewhere)on internet and it's very simple..
"It should work on ANY PC parallel port, and uses a 74LS157 to feed
the data, as two nibbles, into 4 parallel port "printer status"
inputs."
Today it was tested, and works ok.
My name is Dusan, IV (in october V) year student of Electronic in city
of Novi Sad (Serbia).
I work on student project called "voice controller" (very,very
primitive voice recognition).
Marte Schwarz
Hello Dusan,
program.
inputs."
Visal Basic means Windows 9x or above... means that the compuer which will
be used have at least a bidirectional LPT and nearly allways a soundcard on
board. EmbeddedPCs are able to integrate a AD in a more professional way. I
don't see the goal of your project, but lot of trouble (using windows as a
non-realtime system. May you help me a little?
Marte
