I want to add to my power supply which is 0 - 20 V+/- @ 1 A and +5V @ 3A a LCD DMM. I want to use a 9V battery due the load of the LCD will be independent of the circuit.
So I made a search. I want to make the following circuit:
It is capable of switch between each output and to measure the output current. The problem is that I am having difficulties understanding the circuit shown.
I don't understand what is the I-Sense resistor, and the "To +Vout Via Main board" outputs. Do I need to connect this directly to the cable that goes out from the PCB right?
In addition he was talking about: "There are no RF decoupling capacitors in the circuit". Then he added some capacitors, for what this is benefit?
Source: http://www.io.com/~n5fc/xp720.htm
