Adding pre out on soundbar for sub.
Jayded
Aug 16, 2021
I have a soundbar I would like to add a pre out to for a sub. Would it be possible to tap that signal on the pcb, if so any way I could identify it? The manufacturer was no help with getting a diagram.
Thx.
Audioguru
Sep 24, 2016
3,656
The signals inside the soundbar amplifier probably have no deep low frequencies. You must add a low frequencies mixing amplifier at the soundbar inputs to mix together the stereo into mono and have a suitable lowpass filter to feed the sub amplifier.
Does the TV or other signal source produce any deep low frequencies? My stereo speakers produce good bass but I needed to add a bass-boost circuit to the amplifier for my TV.
I added an enclosed two-way speaker to my clock radio but it produced no bass until I modified the circuit with much higher value coupling capacitors, now it sounds like a hifi with wideband frequencies.
crutschow
May 7, 2021
991
What do you use as the sound source to the soundbar: RCA analog, optical, or HDMI?
WHONOES
May 20, 2017
1,242
Who is the maker and what is the model of your sound bar?
Audioguru
Sep 24, 2016
3,656
Some cheap soundbars use little Shriekers instead of speakers. No bass.
