Hi Nab,
Use www.google.com to find out what things are. When you enter CD4017 or LM358 you will get a list of links and a few will be manufacturers' info pages and datasheets. The ICs are available in different package sizes and different temperature ranges which are determined by the letters following their part number. On the info page, click on each listing to see its package size. Usually you want P or N. You don't need A or B extreme temperature ranges used by the military, but C is fine. All 4017 ICs have a B in their part number.
The info page and datasheet for the 4017 describes it as a decade counter with 1 of 10 outputs. Then the datasheet shows that it produces one output at a time, and changes the output each time there is an input that has enough amplitude. The outputs sequence from 1 to 10 and then repeat for each loud sound of any frequency.
If you are playing music with a loud bass beat, if its microphone is at the right distance from a speaker, it will light an LED for each beat, one LED after the other in sequence. If an orchestra is playing, the sequencing will be so fast it will appear like all LEDs are lighted dimly. If the music becomes extremely loud or not very loud, it will stop the sequencing with a single LED lighted until the sound becomes normal volume again. If you speak, it will step its outputs in sequence for each word or syllable if you speak at the right volume.
If you want a circuit to light LEDs when certain frequencies are produced, like some for bass, others for mid-range and others for high frequencies then you need a different circuit called a Colour Organ. I think there are a few projects in our projects section.
