Additional pass through transistor or bigger reg?
Balrock
Mar 1, 2012
39
I have been moving forward with my Bench PSU project and had a look today at increasing its current output. My design (still in breadboard stage) uses LM317 and LM337 regulators so it can provide about 1.5 amp. I was looking at increasing this to around 3 amp.
One option I have looked at is using the same regulators with the addition of pass through "power" transistors. The other option is to use higher rated regulators. What are the pros and cons of each approach.
Thanks for any help given, Paul
14,484
Hi Paul
The LM338 will happily do up to 5 Amps, dont forget to heatsink it.
messing around with lower rated regulator will work well its just a heck of a lot more work and higher component count.
There's no point with pass transistors unless you are wanting over 5Amps, why complicate things more ?? :)
Balrock
Mar 1, 2012
39
Hi Dave. Thanks for the quick reply. Yes I looked at the LM338 but they don't make a negative version of it as my PSU is Dual Rail.
However, I am using 2 x transformers wired together (as I got them cheap) in place of one single unit so would I be correct in saying that if I separate (isolate) and use one transformer per LM338 rail I could wire the + output of the second LM338 to GND (0v) of the first and I would get a dual rail + GND - type configuration.
I hope that made sense!
14,484
ahhhh ok, you didnt state anything about a split rail supply in your first post ;)
14,484
OK here's one example along the lines of what you were thinking
NOTE there is NO connection between the secondaries of the transformer
attachment.php
this came from the www site, down the page a little way .....
http://www.tcaas.btinternet.co.uk/jlhesl.htm
cheers
alfa88
Dec 1, 2010
349
Take a look at my project log. I just posted it a couple of days ago. It uses 2- lm338s. As long as the 2 secondaries are not connected to each other; who needs a negative regulator? I might have gone a little overboard on the heatsinks but that's what I had laying around .
14,484
yup thats what the circuit does that I posted before your post lol ;)
duke37
Jan 9, 2011
5,364
The bridge rectifiers must be connected correctly. It would be better to rotate the diode symbol a quarter turn to the left.
Well spotted.
Balrock
Mar 1, 2012
39
Thanks all! I love this forum! What sweet headache relief it brings :D
Sorry Dave, but in my defense I did quote "uses LM317 and LM337 regulators" ;)
I will forge ahead to my next tangled web of confusion. Thanks again guys.
"NOTE there is NO connection between the secondaries of the transformer" is ok for me Dave as I am actually using 2 smaller transformers anyway.
14,484
yeah till i googled the LM337 I didnt realise it was a neg rail regulator .... never had the need to use one lol
