Ademco Lynx (Rev. 10)
N
newb
Another said:
I have an ademco lynx, it reports to my alpha pager (motorola advisor elite)
via numeric at this time. I was told that it may support alpha numeric
paging that I need to get the modem access number to my pager (which i've
done) and program it to do so. I looked into the programming of my panel
using compass and I'm not sure if it actually does support alpla numeric
paging or which setting to use if so (i.e. contact id report, ademco low
speed, etc.) any help much appreciated.
howzabout pager format
Another Anonymous
Thats not one of the options. Only radionics and ademco formats other than
contact id.
Another Anonymous
Buggs
Mark said:
It doesn't
Sure it does, Mark. Just go into programming section 109 and enter the
"change format" code. I believe it's 8888. Then power down, wait exactly
seven minutes, and power up with the battery only. Wait another seven
minutes and connect AC, but you have to connect both legs at exactly the
same time. Remember, just like the old Vista 1 series.
js
Crash Gordon
7 minutes?...thought it was 3.5 then 3.5 for a TOTAL of 7
Rob
Microsoft MVP - FrontPage
| >> advisor elite) via numeric at this time. I was told that it may
| >> support alpha numeric paging that I need to get the modem access
| >> number to my pager (which i've done) and program it to do so. I
| >> looked into the programming of my panel using compass and I'm not
| >> sure if it actually does support alpla numeric paging or which
| >> setting to use if so (i.e. contact id report, ademco low speed,
| > It doesn't
| js
