Adjustable Voltage Reg LM317, Should it be getting this hot ?
Nick Mulder
Oct 13, 2005
43
I've made the little circuit of resistors around an LM317 adjustable voltage regulator that is specified in its spec sheet (240R bet pin1 and pin2 and a 5k pot bet pin1 and gnd)...
When using a 12v lead acid battery as an input and regulating the output down to to just above 7.2 volts (running a portable DAT machine) the regulator will get too hot to touch - it is rated for 1.5A but during operation the DAT is only drawing from 400mA to just over 1A
I am just using a little clip-on TO220 heat sink with a little blob of compound
Question : is this heat sink enough ? is "too hot to touch" ok for the regulator ? or do I need a better heat sink or other solution ?
I am only leaving it on for a few minutes at the moment, would like to be sure I can leave it running at that heat ...
The operating temperature in the spec sheet says 0deg < T < 125deg
audioguru2
Apr 6, 2004
12,022
Hi Nick,
Your little heatsink is too small.
The max internal temperature of the junction of the LM317 is 125 degrees C, the thermal resistance from its junction to its case is 4 degrees per Watt and you have it dissipating (12V-7.2V) x 1A= 4.8W, so if its case is at 106 degrees C then it is too hot. It lasts longer if is cooled properly.
The LM317 is smart. It shuts down if it gets too hot, at about 135 degrees C internally. Then it will cool and start working again. They say not to let it heat and cool like that too many times or it will fail with fatigue.
Nick Mulder
Oct 13, 2005
43
ok, its off to the store for me ...
thanks for the answer, I would have gotten one anyway but its nice to have a heads up to the actual numbers involved - Data sheets can still read like the dead sea scrolls to me, but more and more lately the specs are starting to be meaningful -
all good + cheers!
nick
audioguru2
Apr 6, 2004
12,022
Altronics got the resistor value wrong, the 240 ohms should be 120 ohms with an LM317.
240 ohms is OK for the more expensive LM117.
They also got its max output current wrong. Its output current is 1.5A, not just 1A and not 3A.
LostViking
May 22, 2007
36
And not all LM317's are created equally. The LM317T has thermal shut down.
audioguru2
Apr 6, 2004
12,022
No, they all have thermal shut down because they all use the same chip.
National Semi supplies the LM317 in 7 different packages. The T is the TO-220 package, the K is the TO-3 package and there are a few tiny surface-mount packages.
LostViking
May 22, 2007
36
OK, you got me on that one AudioGuru. I should have reviewed the datasheet before posting, rather than relying on memory that has faded.
micro_1
May 9, 2007
7
Hi LostViking,
I do appreciate your passion in replying to postings. This is the way to learn. You feel frustrating if nobody reply to your posting.
regards,
waferstar
Aug 19, 2005
46
That should be very hot,
the efficient is about 66% .... so that is overload of LM317
I think you can change to use : LM2576,that would be very good.because that is switching power chips.
www.mcuservice.com
