Adjusting a Ferguson TV picture size. - model FTV210N.
Albert Grennock
Laurence Taylor said:
It is against the creadit card company's terms to give a cash refund
on a card sale - it has to go back to the card it was debited against.
Not a credit card its a debit card, I don't live on credit like many.
Tom MacIntyre
Sounds like its time for you to start your own fan club...
Tom
Albert Grennock
No need, the existing ones do an excellent job, some fantastic websites too.
ChrisCoaster
If I may interject - I have a 2004 model 24" flat tube Toshiba with
hidden service menus that even Bush could understand and manipulate.
So not all service menus consist of hieroglyphics. : )
I've got that bugger so squared up and true just using the THX patterns
on the Star Wars trilogy, I have HD pals with 54" widescreens that
spend more time in front of my set than those.
Try this site for menu info on some sets:
http://www.artofhacking.com/files/TVMODES.TXT
OR:
http://myweb.accessus.net/~090/how2adj.html (excellent site!)
-CC
I
inti2
Albert Grennock said:
Hi
I just bought a Ferguson FTV10N television (might be FTV21ON)
and the picture is a little to big in that the scrolling text at the bottom
of Sky news and BBC news 24 is a little cut off at the bottom.
(basiclly the picture is too big vertiaclly).
Fine I though, I will just find the vertical adjust 'thing' inside the TV
and twiddle that. Trouble is there does not appear to be such a 'thing'
to twiddle. (Not really a great deal inside compared to a real old
television so I assume I have not failed to locate it).
So how do I adjust the picture size (vertically)?
Maybe you can make the adjustements you need in the service mode...
can you identify what chassis has this thing ? ICC20 ? ICC21 ? ICC17 ?
They're all-digital chassises, without potentiometers or trimmers...
Also who make Ferguson televisions? Do they have a
website? I assume its a brand name but I cannot seem to
locate the manufacturer or a website for Ferguson support.
Ferguson TV Sets are made by Thomson
I guess the lesson is never buy a Ferguson televisioni.
I.
Albert Grennock
I had a look around for a chassis number but to be honest I was not
too sure where to look, where are they normally found. I tried the
back cover mainboard and even the tube but I could not find any
thing which resembled a chassis number.
Anyway I have returned it to the shop for a refund.
All the other ones on display had the same fault any so I doubt it is
easilly repairable, that fact does not discourage Curry, to their discredit,
continuing selling them.
F
fireater
Albert said:
Hi
Any help appreciated.
Tia.
well here in canada i would say if the vert size is off some of the
capacitors around the vertical driver circuit are failing. I usually
replace all the caps in the general area of the vertical output.
example : if the vert output is ic308 and the caps near it are c
301...302...304... etc i replace every cap i find in the 300 number
designation. Now that being said is this a uk set? as in PAL? cause i
have never worked on a pal set although similar problems im sure exist
in these circuits as well.
