Adjusting LED color temp?
lynkynpark86
Oct 22, 2011
8
I want to make a light that has 4 white LEDs, a red LED, and a blue LED. I want to have a know that controls the blue-red ratio. Is this possible with only a variable resistor (highest resistance = red at capacity, blue off; lowest resistance = red off, blue at capacity)?
XmodAlloy
Mar 21, 2012
11
That is certainly possible! You simply need a pulse width modulator and an output inverter. Run the blue off the PWM output and the red LED off the inverter.
I personally like this: http://www.robotroom.com/PWM.html PWM schematic, very easy to build on a single layer board.
Good luck!
KJ6EAD
Aug 13, 2011
1,114
What are you using for power; batteries, regulated supply or unregulated supply?
