Advanced Battery Technologies
stube401
Feb 10, 2010
71
I've recently been doing some work with lead-acid batteries. As most of you know, these things are nuts in terms of the amount of power they can deliver - effectively they are a power supply that can deliver hundreds of amps in a small space of time. The upper limit is only defined by the limits of the chemical equation going on inside, coupled with the melting point of the matterials used to make the battery.
I'm wondering if there's any existing or new battery technologies that have an inherently more stable chemical equation that results in some sort of integral virtual current limiting or current control?
It's been a while since my high-school chemistry lessons, but maybe there are some chemical equations that cannot be speeded up? The assumption here is that the speed at which the chemical equation takes place is proportional to the power delivery.
Can anyone can shed any light on this?
Alex Tsekenis
Nov 29, 2009
299
I do not know the answer to this but it will probably be in this book:
http://www.amazon.co.uk/Handbook-Batteries-David-Linden/dp/0071359788/ref=sr_1_2?ie=UTF8&s=books&qid=1268218232&sr=8-2
Silent Jack
Mar 9, 2009
113
Are you trying to determine the power limitations of lead acid type batteries for a given application or simple looking at theoretical limits?
audioguru2
Apr 6, 2004
12,026
Try calcium ?
A calcium battery?? Lithium-polymer is much better.
Since you are talking about calcium, when I was a teenager I became crippled. I could barely walk and could not run fast anymore. The doctor chopped off a calcium deposit on a bone in my ankle and then I was fine. The scar is barely visible.
[move] ;D ;D ;D[/move]
Stephenah
Apr 20, 2010
17
???sorry  I don't answer  but I found it ,Silver-zinc battery energy than large, to a large current discharge, seismic, for Astronauts, satellites, rockets and other power. Charge and discharge times up to about 100 to 150 cycles. The drawback is that expensive, relatively short life.
