advanced l/c meter
peter g
Jun 18, 2017
7
hi all, just joined the forum. my name is  pete and I live in s. florida. i'am a retired electronics field service tech for Philips . I built an l/c meter I found on an web site. its called LCM3. it works very well. I have some questions about the ESR in circuit measurements. there is a probe that you construct for this purpose. how do you calibrate the meter with this probe in place? should the meter display both the capacitance and the esr value? I burned the pic with Ver.1.25. does this code implement in circuit measurement or do you have to use Ver.1.35? the article for this meter can be found here: [email protected]  p.s. i'am in the process of building Mike's version of this meter.
admin2
Administrator
Administrator
Mar 13, 2015
184
Hi Peter and welcome to the community. Could you share your thoughts building this LC meter and if everything worked right from the beginning.
peter g
Jun 18, 2017
7
yes, the meter worked fine. I have built many esr meters, both analog and digital.
admin2
Administrator
Administrator
Mar 13, 2015
184
Can you point us to the most interesting ESR meter you've build?
peter g
Jun 18, 2017
7
yes, the meter that is really good is called LCM3. google it, I really like it, as it reads both capacitance and esr at the same time in circuit ,most of the time.
