K
kony
- Jan 1, 1970
- 0
I'm just musing, please correct where I'm right off track.
It's current that causes heat rise (I^2R).
.... and voltage (accuracy of voltage control method), and
frequency.
For things to work, current
must flow, and for current to flow, voltage must be applied.
Fair enough
For
minaturisation, smaller currents will need higher voltages.
No with current tech, miniaturization means lower voltage is
required but losses become higher. Thus current higher
too.
For things to go faster, larger currents are required, and so larger
voltages are required to push these currents.
No, see above. For things to get substantially faster we'd
need a shift in technology, either different manufacturing
method and material or what they're presently doing, just
tacking on addt'l cores they can fit in space allowed by a
certain process size shrink - onto the point where it
becomes unaffordable to make it a larger core.
If you limit to non-fan
cooling,
Why this arbitrary stipulation?
you limit current, and therefore limit speed and capacity.
Yes within any given tech, if you target a thermal design
power low enough that *reasonable* passive cooling is
possible, you will limit _voltage_ which inherantly limits
current, and these two limitations using a given tech,
inherantly limit the ceiling speed that tech can sustain
stabily. I don't know what you mean by capacity except to
the extent that a given tech and process size with a given
voltage will require X amount of current per amount of
*circuitry*, or in a logical sense, limiting circuitry or
stable attainable speed within the aforementioned
limitations (given same tech) limits performance (though
optimizable for certain tasks the more one specializes in
specific function CPUs instead of broader operations like in
a PC).
