Advice cleaning game cartridges without causing corrosion
Recordable2000
Aug 13, 2023
9
Hello everyone, I have many famiclone (nes clone) cartridges and I want to clean them to a degree where I don't need to constantly clean them with alcohol for them to work. I posted some examples of how they look (the examples are already clean, I have many more to clean). Some of these are very stubborn with years of dirt on them, so cleaning some of them with alchol is ineffective.
Now to the point
I have determined washing them with baking soda or washing powder in water gives the best results in making the pins look and work brand new. However , I am worried about the long term sideffects of this mettod. If I wash a pcb for around 2-3 minutes each, then blow out the water underneath the chips with a compressed air spray and afterwards dry out the pcb with a hairdryer, would that cause problems after a period of time? My question is would it corrode pins/ traces or damage the chips and epoxy blobs on the board?
I'm sorry for my bad english, not a native speaker.
Delta Prime
Jul 29, 2020
2,991
Baking soda is okay make a paste out of it there should be no excess water anywhere!That you have to blow out. I use a pencil eraser a "new one" and rub that onto the contacts "vigorously"
this way you will not damage or have any water anywhere. And after that I clean with at least 91% isopropyl alcohol
(Rubbing alcohol) Again!! Do not use anything less than 91% rubbing alcohol.
It should look like the photo below.
The reason why you have to reapply alcohol to clean them after you thought they were clean is they were not thoroughly cleaned try the pencil eraser and 99.9% alcohol I only have to clean them once. But even with that said
They will oxidize there's no avoiding that. But that's months later. If you stick those dirty cartridges in your console then you're going to have to open up your console and you don't want to do that.
An everyday run-of-the-mill pencil rubber (white one) has been found to be a good tool for cleaning contacts such as this.
