OK – I’ll have to tip my hat to Resqueline on this one. I didn’t think it would be so simple – but this idea was sticking in my craw – so I tossed together a test mule today during my lunch hour, and it works pretty well. The mag switches I had readily available for the test were Hamlin DRR-129 series – these ones are rated at around 50 Ampere-Turns in sensitivity. In our usage in ATE, they’re usually associated with a Coto 24VDC solenoid coil – a 1300 series.
When designing the coil, I decided on 5W max power loss at 25A as a limit – and estimated a coil length of around 1.25 inches as being about right to stay centered over the sweet spot of the switch, which is 2 inches (max) in length. I picked 16 AWG magnet wire as being about right to meet the coil length to make up 0.008Ω. The coil form I picked off my desk to wind the wire on was a plastic soldering tool – 0.245 in diameter. The length of wire was selected from a wire chart for DC resistance – and the ends stripped and tinned and tested for resistance before winding. The finished coil length is 1.30 inches, and 22 turns total. It could be tightened up a bit with more careful winding – but remember – this was a quick lunch break project. I put two layers of heat shrink over the glass switch – which is 0.207 max in diameter – then slipped the switch into the coil. I connected to an IR 110MT80KB bridge rectifier for the test. This is an 800V 110A bridge – much bigger than needed – but again, I was in a hurry, and I had a box of these in my office. This bridge is also big enough in size that I didn’t need to worry too much about heat sinking during the test.
The test results were surprising. The switch pulls in at 3.0A – or 66 Amp-Turns – and drops out at 1.80A (40 AT). As would be expected with 5W dissipation – the coil gets pretty hot up at 25A current – but the switch works fine there, and doesn’t stick from the high flux, or drop out from the initial temperature rise. I imagine that after awhile up at full power, this particular design would eventually reach the curie temp of the reed elements, and they would fail. But with a little dialing-in of the wire size, and limiting current to keep temperature rise under control – the concept will work.
