Advice on a prop electronics project
Lunchbox739
Sep 28, 2021
Let me know if im barking up the wrong tree here please. Im working on a costume project and im wondering if there is a way to add a light animation to a set of Home Starry fairy lights or if id be better served with a more customized approach. The prop is for a child so im not looking to duplicate animations of the hollywood prop, just want to get it in the ballpark.
14,317
There seem t be different versions of "Home Starry fairy lights". Which one do you intend to use?
Do you want colored lights, animated, or simply a string of LEDs that is turned on or off?
Lunchbox739
Sep 28, 2021
The ones i have can be a specific color or cycle through the colors fading into each. Itd be ideal if I could get them to scan, where one or two leds at a time in sequence down the string.
14,317
I'm afraid that will not be possible. This kind of lights is usually made of RGB LED which are all in parallel , so all are of the same color at any time.
Have a look at this kind of LED string. It has "8 memory modes (Combination, In Wave, Sequential, Slo Glo, Chasing, Slow Fade, Twinkle,Steady On)" which may be exactly what you want.
Entirely possible with WS2812 based LEDs, but probably not within the range of your possibilities (need microcontroller plus programming), Plus in total likely to be more expensive than the above linked strip. On the other hand a good exercise to start in the world of programming microcontrollers. If this is for Halloween, the time frame may be a tad short to get you going from scratch using his approach.
