HodgdonExtreme
- Mar 11, 2016
- 3
- Joined
- Mar 11, 2016
- Messages
- 3
Hi, new member here. I'm not even well-versed enough with electronics to be considered a newbie. I'm working on a project that I believe ought to be pretty simple and I'm looking for suggestions on what parts/products to put together to achieve it.
I have 8 analog (voltage) signals I need to transmit wirelessly ~1000ft or so. The plan is to ultimately use a tablet with custom programming to create a GUI/readout.
The ADC will need to be a minimum of 18bit, but 20 or 22 would be better. The signal acquisition speed is not critical, even just 10 samples/second would be plenty.
Additionally, the signals are coming from transducers that require a clean/steady 5-10 VDC power supply, so the transmitting unit will not only need to perform the data acquisition, but provide the excitation voltage for the transducers. This unit will need to be battery operated.
Anyone got suggestions for suitable products I could use to do this?
