Hello everyone,
First off I'd like to thank you for visiting the my thread. Each time I've come to this forum I've left with assistance and more knowledge and because of this forum in the last year I developed a working device for myself. But I'm sure you all know that when you personally build something it usually can never be considered perfect!
With that said I know my device is not perfect and I know how to fix it. I just physically don't know how to build that fix!! Hopefully you all can help.
My device now is a simple piezo hooked up to a lever switch. When the switch gets hit of course the piezo beeps. I have it hooked up to a 9V via a simple 9V connector and the lever switch I used little connector spades clamped to the wires. (I can take a picture if needed - but probably not.)
Anyways, the lever is usually at rest (90% of the time) but when it is struck it's multiple times and fairly quickly usually. Occassionally the piezo will skip or the tone will blend. I know a timer will help but I'm not good with this sort of stuff.
First of all, I know I need a board for this to go on. All the ones I see at RS and the like - even the smallest ones are too big to fit in the housing I need it to. Can you cut those boards to size, carefully of course? Next, I'd like to add a button cell to the device rather than a 9V (if possible), I'm not sure how I'd achieve this. Going in line with how the device would operate, I'd like to add an on/off switch as my current build doesn't have one. I noticed however a lot of those were like the lever switch - they had "prongs" on the bottom... I'm not sure how you would attach those to the board.
Then I'm not sure where you would put the timer. I imagine between the lever switch and piezo.
As you can see I've got this worked out fairly well (I think!) but I'm just not very good at electronics. I've read a lot of resources but having no hands on experience is tough.
If anyone could lend any general assistance with how I could accomplish this I'd appreciate it very much!!!
