AM electromagnetic waves: 20 KHz modulation frequency on an astronomically-low carrier frequency
Bob Myers
First of all, do you think you could possibly learn to trim your posts?
No nonlinearity is necessary in order to hear
a beat?
Where does the beat come from?
An audible beat tone is produced by the constructive and destructive
interference between two sound waves in air. Look at a pictorial
representation (in the time domain) of the sum of sine waves,of similar
amplitudes, one at, say, 1000 Hz and the other at 1005, and you'll
see it.
Bob M.
John Smith I
Tommy said:
Your expansion of the original and simple question into a convoluted and
obfuscated mess shows an outstanding knack for skills related to the
psychotic ... however, it also shows you to be an idiot.
Hey, are you attempting to fake a mental disorder so you can get off
welfare and onto SSI?
Sharpen your razor blade, return to the mental hospital--begin splitting
hairs ...
JS
RHF
hairs ...
JS
Ah the War-of-the-Words continues ~ RHF
I
isw
--snippage--
When I was tuned to the 3rd harmonic sometimes
I would hear it and sometimes not.
It would come and go rather abruptly. It didn't seem
to be gradual fading.
Especially if the RF field is strong, there are a lot of mechanisms
which can create harmonics after the signal leaves the transmitter --
rusty fencing, or tooth fillings, for example. I can see how one of
those could be intermittent.
The you understand Fourier transforms and convolution.
I suppose so; I've spent over fifteen years poking around in the
entrails of MPEG...
As I suspected -- just different words for the same thing.
So:
With well-designed gear (or theoretically), for AM there will be no
other frequencies present except for the carrier and the ones
represented by the Fourier spectrum of the modulation -- one set either
side of the carrier. That is only true, of course, as long as there is
no overmodulation; that creates a *lot* of other junk, because there are
periods where the carrier is entirely cut off.
So I still don't understand what you mean by "triple frequency
sidebands" or "basic sidebands".
As I said in another post, modulation is a "rate effect", so there never
should be any frequencies generated at multiples of the sidebands
surrounding the fundamental; instead they are always identically as far
from the harmonics as they are from the fundamental. Is that what you
are calling "triple frequency sidebands"?
Isaac
RHF
Hi:
Please don't be annoyed/offended by my question as I decreased the
modulation frequency to where it would actually be realistic.
I have a very weird question about electromagnetic radiation,
carriers, and modulators.
Is it mathematically-possible to carry a modulator signal [in this
case, a pure-sine-wave-tone] with a frequency of 20 KHz and an
amplitude of 1-watt-per-meter-squared on a AM carrier signal whose
frequency is 10^-(1,000,000,000-to-the-power-10^1,000,000,000)
nanocycle* every 10^1,000,000,000-to-the-power-10^1,000,000,000 giga-
eons and whose amplitude is a minimum of 10^1,000,000,000-to-the-
power-10^1,000,000,000 gigaphotons per 10^-(1,000,000,000-to-the-
power-10^1,000,000,000) nanosecond?
If it is not mathematically-possible, then please explain why.
10^-(1,000,000,000-to-the-power-10^1,000,000,000) second is an
extremely short amount of time. 10^-(1,000,000,000-to-the-
power-10^1,000,000,000) nanosecond is even shorter because a
nanosecond is shorter than a second.
Giga-eon = a billion eons
Eon = a billion years
*nanocycle = billionth of a cycle
Gigaphoton = a billion photons
10^1,000,000,000-to-the-power-10^1,000,000,000 -- now that is one
large large number.
10^1,000,000,000 = 10-to-the-power-1,000,000,000
So you get:
(10-to-the-power-1,000,000,000) to the power (10-to-the-
10^-(1,000,000,000-to-the-power-10^1,000,000,000) = 10^-(10-to-the-
power-1,000,000,000)-to-the-power-(10-to-the-power-1,000,000,000)
10^-(10-to-the-power-1,000,000,000) to the power (10-to-the-
power-1,000,000,000) is an extremely small number at it equals 10-to-
the-power-NEGATIVE-[(10-to-the-power-1,000,000,000) to the power (10-
to-the-power-1,000,000,000)]
No offense but please respond with reasonable answers & keep out the
jokes, off-topic nonsense, taunts, insults, and trivializations. I am
really interested in this.
Radium
WHAT WAS "RADIUM'S" ORIGINAL QUESTION ?
-and- HAS IT BEEN ANSWERED ?
Hi:
large large number.
So you get:
Radium
Ron Baker, Pluralitas!
see it.
Bob M.
How come you don't hear a 200 Hz beat
with a 1000 Hz tone and a 1200 Hz tone?
DTC
What we used to call miscellaneous metallic junction intermod.
Bob Myers
Apparently, no, you can't. Too lazy to take the trouble to
perform this common courtesy, or what?
For the simple reason that there isn't actually a "tone" involved -
in other words, there is no actual signal at the difference frequency.
There can't be, since there is no "mixing" (multiplication) of the
two original tones. The "beat" is really just the perception of
the amplitude variation caused by the interference previously
mentioned. You cannot sense such variations if they occur
rapidly enough, any more than you can detect the flicker of a
light source which is varying rapidly enough.
Bob M.
Bob Myers
That's easy. Radium has never actually had an original
question. All of his questions are either rehashing very
well-understood situations, or are utterly nonsensical and
therefore not answerable AS legitimate questions.
Bob M.
Elmo P. Shagnasty
Bob M.
Are you saying that John Navas *also* posts under the name "Radium"?
Eeyore
Does it matter ?
It's only attention seeking.
Graham
RHF
- Does it matter ?
- It's only attention seeking.
- Graham
Graham - Thank You for the Attention :eek:) ~ RHF
- - - You are Reply # 228 . . . and still Counting.
You could always plonk me.
two original tones.
There is no multiplication of 1000 Hz and 1005 Hz
either, is there? Why don't you hear 1000 Hz and
1005 Hz rather than a single tone varying in amplitude?
Bob M.
Could it be that the human auditory system is not
linear?
Don Bowey said:
Don Bowey said:
On 7/4/07 10:16 AM, in article [email protected],
On 7/4/07 7:52 AM, in article
[email protected],
"Ron
<snip>
cos(a) * cos(b) = 0.5 * (cos[a+b] + cos[a-b])
Basically: multiplying two sine waves is
the same as adding the (half amplitude)
sum and difference frequencies.
No, they aren't the same at all, they only appear to be the same
before
they are examined. The two sidebands will not have the correct phase
relationship.
What do you mean? What is the "correct"
relationship?
One could, temporarily, mistake the added combination for a full
carrier
with independent sidebands, however.
(For sines it is
sin(a) * sin(b) = 0.5 * (cos[a-b]-cos[a+b])
= 0.5 * (sin[a-b+90degrees] - sin[a+b+90degrees])
= 0.5 * (sin[a-b+90degrees] + sin[a+b-90degrees])
rb
When AM is correctly accomplished (a single voiceband signal is
modulated
The questions I posed were not about AM. The
subject could have been viewed as DSB but that
wasn't the specific intent either.
You should take some time to more carefully frame your questions.
Do you understand that a DSB signal *is* AM?
So all the AM broadcasters are wasting money by
generating a carrier?
Rich Grise said:
Have you ever actually observed this effect?
Rich
I have.
I tuned to the third harmonic of a strong local
AM broadcast station. There it was. Quite
a surprise. It is a bit distorted but intelligible.
Another odd thing is that it comes and goes
somewhat abruptly.
I
isw
--snippety-snip--
Then linearity is at the core of the matter.
What does "linear" (or "nonlinear") mean to you?
OK, if you insist -- *in this case* it means "linear enough to not
produce IM products of significant amplitude".
a beat?
As the phase of the two nearly equal waves move past each other, there
is simple vector summation which varies the amplitude.
Consider two sine waves of precisely the same frequency, where one of
them is adjustable in phase -- use a goniometer, for instance. Use a set
of resistors to sum the two signals, and observe the summing point with
a 'scope or a loudspeaker. By altering the phase of one source, you can
get any amplitude you want from zero up to twice the amplitude of either
one.
Now just twiddle that phase knob around and around as fast as you can.
You've just slightly altered the instantaneous frequency of one of the
generators (but only while you twiddle), and accomplished pretty much
the same effect as listening to the beat between two guitar strings at
nearly zero frequency offset. With no nonlinear processes in sight.
Isaac
Don Bowey
[email protected],
"Ron
<snip>
before
relationship.
relationship?
carrier
(For sines it is
rb
modulated
You are an ignorant, useless troll, and not worth my time
m II
linear?
No. Humans had to evolve to incorporate a non linear response to sound
when the electronics manufacturers started supplying ONLY non linear
potentiometers for audio equipment use.
This mutation, which is now the norm, was completely unknown before the
start of the twentieth century.
We, here at Densa Labs, call it Darwinian Decibelism
mike
