amp with high frequency noise
regward
Aug 13, 2011
4
I have a fender deville 212,I had it about 7 months great sounding amp.The only problem I have, is it makes a very high frequency noise,and it only does when I"am playing gigs.I took it too the shop they could not fix because it, only happens when I actually play gigs what could be causing the problem thanks Reggie
regward
Aug 13, 2011
4
I have a fender deville 212,I had it about 7 months great sounding amp.The only problem I have, is it makes a very high frequency noise,and it only does it when I"am playing gigs.I took it too the shop they could not fix because it, only happens when I actually play gigs, So I thought maybe its tube related is that possible?Please respond back let me get some ideals, so when I take it back to the shop I can recommend something.Thanks Reggie
When you're setting up for the next gig, set the amp up first, and as you connect up other gear, test to see if the fault is happening.
It may well be some other piece of gear.
regward
Aug 13, 2011
4
I pull out the cord going into the amp and it still makes that sound,a high pitch piercing sound
14,484
do you have a microphone going into the amp as well ?
hi pitched squealing is usually a sign of feedback with microphone too close to the speaker and or the mic level too high
regward
Aug 13, 2011
4
No mic just guitar and a couple of stompboxes
poor mystic
Apr 8, 2011
1,106
So there is a noise in the amp when you're out playing gigs, but at home/practise it's OK.
The gig environment might be electrically noisy. I'd be looking at power supply filtering in your amp, at this stage.
duke37
Jan 9, 2011
5,364
You say that it is a tube (valve) amplifier. Valves are microphonic and will act as a microphone giving audio feedback.
Options
1 Play quiet chamber music
2. Keep the amp well away from the speakers.
3. Keep the volume down to a safe level.
4. Change to a transistor amplifier.
5..Find out which valve is causing the trouble and replace with a ruggedised version.
