Amplification and loss
Kevin Weddle
Feb 23, 2004
1,620
Is loss in amplifiers any indication of design? Could you design a good amplifier with a lot of loss? A resistor causes loss, but no distortion. Many times I have had to reduce a signal after amplifying it. Is this a design problem?
audioguru2
Apr 6, 2004
12,026
An amplifier has gain, not loss. You can reduce the gain with negative feedback or reduce the input and output with a volume control at the input.
If you need to reduce a signal after amplifying it then the input level is too high or the amplifier's gain is too high.
If your amplifier causes distortion then it has a design problem.
Kevin Weddle
Feb 23, 2004
1,620
But shouldn't loss, as in the way of resistors be avoided. Of course discrete component circuits use them, but isn't it because of the necessity to complete the design. It's a way of interfacing circuit sections and is a concession in a design.
audioguru2
Apr 6, 2004
12,026
It is desirable for an audio amplifier to have extremely low distortion. Then it has a very high open-loop gain and uses plenty of negative feedback to reduce the gain to a useable amount and the negative feedback reduces the already fairly low distortion.
If you attenuate a signal so that an audio amplifier can have a high gain without much negative feedback then its distortion will be much higher.
If an audio amplifier needs to have a high gain like for a microphone then a low distortion preamp amplifies the signal so that a very low distortion power amplifier can be used.
