Amplified Difference op-amp configuration questions
duke37
Jan 9, 2011
5,364
How accurate do you need to be?
Resistors are fairly cheap so you could buy a handful of 1% resistors and sort them.
If they all come from the same batch they will be similar and have a similar temperature coefficient.
You will need some high class measurement to do this.
harris_p
Feb 18, 2013
Well, let me expand on this...
I'm trying to control some galvos. These units require a balanced bipolar differential signal (max of +10V differential, min of -10v differential, center = 0v differential). The output on the ILDA_Y+ line will swing from -5V to +5V and the ILDA_Y- line will be the exact inverse. The Y line on the left side that runs to a 16 bit dac that has a min output of 0v and a max output of 4.096v.
This circuit has a few problems:
1. The op-amp voltage offset from zero issue. Due to this propperty of op-amps, I get a little bit of a "dead zone" in the central dac value range.
I'm using op-amps with a voltage offset of 500uV.. but ideally would like this to be zero. I'm not sure what else I can do here aside buying more expensive op amps?
2. The dual pot solution works, but is tedious to tune. I was hoping there was a way to do this with only one pot.
