amplify load cell output
steverod
Jul 4, 2024
5
Hi folks. I want to feed the output of a load cell into a little 555 sound generator. How do I amplify the signal to do this? Many thanks.
14,317
A simple opamp circuit can do the job.
Please supply more detail like:
  • more detail of the load cell's output
  • a schematic of your 555 circuit
  • a more detailed description what the effect of the load cell's output on the 555 circuit shall be
  • what power supply(ies) are being used. Note that with a single supply you may (or may not, depending on the circuit's details) need a rail-2-rail opamp
steverod
Jul 4, 2024
5
Thanks for getting back so soon. The load cell is this one: https://www.ebay.co.uk/itm/314541831911?var=613097026384 but I don't want to use the HX711. I want to input the load cell into the NE555n pictured below. I made it years ago and have lost the schematic. Also, I may be in the wrong forum as I know next to nothing about electronics. Thanks again. edit: the 555 is 9V I'd like to excite the load cell with something similar (though I think it likes 5V. I've just seen this: https://maker.pro/forums/threads/audio-amplifier-to-amplify-a-load-cell-signal.280337/ Will read up on instrumentation amplifiers.
danadak
Feb 19, 2021
1,104
steverod
Jul 4, 2024
5
I just bought the
AD520JD for £6.95. If nothing else I thought I could have fun with it.​
danadak
Feb 19, 2021
1,104
The low cost 620 not great in common mode range, in and out.
Just keep that in mind when designing.
Regards, Dana.
