Amusing failure in Omega analogue watch
F
F Murtz
Tom said:
I've stopped wearing watch about 20 years ago and never missesd it.
Funyy thing I've bought a couple since then (I like nice watch) but they
just sit in a drawer.
Tom
Stopped wearing a watch when mobile phones came out.
David L. Jones
William said:
I don't know what the Omega back is like -- it might require some
special, hard-to-obtain tool -- so I can't give a definitive answer.
The most-common backs use either a slotted ring -- which can often be
removed with a pair of chain-nose pliars -- or a press-to-fit back,
which is removed with a "case-back knife".
The latter is simply a knife with a very thin blade. You simply press
the knife into the seam, and twist a bit. (Well, that's the theory.
It's sometimes a bit more difficult, and there is the chance of
scracthing the back.)
These are available from Zantech (http://www.zantechinc.com/store).
They have all kinds of watch-repair equipment and supplies. You'll
have fun browsing the site.
You can get batteries even cheaper than that from Zantech and similar
companies.
Any jeweler who charges more than $5 for a battery replacement --
including the battery -- is gouging. Most batteries cost the dealer
less than 25 cents, and replacing one takes less than five minutes.
That's a gross profit of more than $50 an hour. Not bad.
That depends on the type of watch.
If you've got a proper 200m pressure rated watch for example, you have to
(or should) inspect or (more usually) replace the o-ring, grease it up
again, and do a full pressure test after it's all done.
If you don't like changing batteries, Casio (and probably others) have
watches rated for a 10 year battery life.
Dave.
David L. Jones
I still wear a wrist watch for the same reason I still have a real
calculator on my desk instead of using the PC.
Dave.
W
William Sommerwerck
An Omega watch of any kind is a high quality instrument for life. Its
long term accuracy will far exceed any off the shelf lower end watch.
I've owned "cheap" watches that were accurate to within a few seconds a
month.
This is obviously a matter of taste, but I've always found Omega's case
design fussy and unattractive. Excuse me, that's Rolex. Sorry.
W
William Sommerwerck
I have an Omega *real* analog auto-wind (no battery) from the early
sixties
that still runs like a swiss clock (cough!). It has a "one-piece-case" i.e. no
rear access -- probably part of the 100m immersion rating. It needs a special
tool which apparently flexes the glass/perspec/acrylic front to remove it.
If it's a "good" watch, it has a mineral cover, not plastic. Some watches
have undoped sapphire (aluminum oxide) covers.
Don McKenzie
geoff said:
And ?
I'll give you $35 dollars for it - same cost as the battery you can't
justify investing in !
geoff
thanks Geoff, caught me out!
Best I pass on that one. A gold engraved $2000 retirement watch, will
end up with the grand kids, when I fall off the perch.
They can then sell it for $35. :)
Don...
Don McKenzie
Site Map: http://www.dontronics.com/sitemap
E-Mail Contact Page: http://www.dontronics.com/email
Web Camera Page: http://www.dontronics.com/webcam
No More Damn Spam: http://www.dontronics.com/spam
Breakout, Prototype, Development, & Robotics Boards:
http://www.dontronics-shop.com/sparkfun-electronics.html
Coupon Specials:
http://www.dontronics-shop.com/coupon-specials.html
Similar threads
