An OPAMP with input offset voltage
fgda
May 26, 2013
1. The problem statement, all variables and given/known data
2. Relevant equations
Superposition
Non-inverting OPAMP: V_out = (1 + R/R)V_in = 2*V_in2
Inverting OPAMP: V_out = -V_in
V_os = 2.5mV
3. The attempt at a solution
1. V_in enabled, V_os disabled
V_out1 = -V_in
2. V_os enabled, V_in disabled
To get V_out2, use the non inv. equation where V_in2 is equal to V_1 + V_os
where V_1 is the node between R and R at the middle bottom of the circuit.
V_out2 = 2*(V_1 + V_os)
3. V_out = V_out1 + V_out2
Is this the correct approach?
Thanks in advance :)
fgda
May 26, 2013
I'm pretty sure that step 2 is correct. The professor did an example in class that was similar enough to that case. But in step 1, I have input voltage at both OPAMP terminals so I do not know what to do. I'd rather take the OPAMP as a black box with a characteristic equation if possible.
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
OK I'll have a go. I have to assume that the op-amp has infinite input resistance.
The formulas for the voltages at the two op-amp inputs are:
1. . V_inverting_input = (Vin + Vout) / 2
2. . V_non_inverting_input = Vout / 6
This circuit has one stable condition because there is more negative feedback than positive feedback.
Vin = +2.2V and the input offset voltage is 0.0025V. The question doesn't state which way the inputs are offset so I'll state the offset as +/- 0.0025V.
3. . Vout / 6 = ((Vout + 2.2) / 2) +/- 0.0025
After some simple rearrangements this formula yields
4. . Vout = - (3.3 +/- 0.0075)
Assuming no op-amp input offset, Vout = -3.3V. Plugging 2.2V and -3.3V into formulas 1 and 2 gives -0.55V for both op-amp inputs.
With the input offset voltage included, Vout = -3.2925 or Vout = -3.3075 depending on the polarity of the offset.
BTW shouldn't this be in the homework forum?
Disclaimer: I think I have a complete understanding of the problem, and I think these explanations and formulas are comprehensively correct, accurate, and perfectly reasoned, but I could be completely wrong!
