analog input frequency counter with binary output.
Qasim1
Jun 16, 2004
10
i want to have an ic that takes the incoming analog frequency as an input and straight away giving the binary on its output pins.The range should be from 1khz to 20 khz.
GPG1
May 3, 2004
71
How many digits/resolution? What type of output, BCD, LED, LCD?
Qasim1
Jun 16, 2004
10
just takes input as a tone ranging from 1-10khz and giving BCD as output.
Kevin Weddle
Feb 23, 2004
1,620
It's the first part you will have trouble with; a frequency measuring circuit. This is done with a differential amplifier. You compare the two frequencies, of the same phase, giving you a zero output. The phase part is the hardest. You will need to set the phase up using two generated clocks. One clock is the signal, the other clock is the reference oscillator.
