anemometer
jacub
I'm going to build simply hot-wire anemometer. It have to work width
3,3V supply. Precision: 1 meter per second. Full scale: 0m/s to 30m/s.
Have you any idea?
John Fields
Have you any idea?
F
Fred Bloggs
Have you any idea?
Run a search through Electronic Design or EDN for design ideas by
Woodward- he has several good anemometer designs published. The 3.3V
limitation will have to be handled by boost power supplies on board.
W
Winfield Hill
jacub wrote...
Have you any idea?
You won't be able to achieve 3% precision over the whole range.
F
Fred Bloggs
Winfield said:
jacub wrote...
He wants a digital circuit anyway.
jacub
Have you any idea?
Hmm. What do You think about idea with Wheatston bridge and broken bulb.
Voltage from bridge will be passed on ADC converter.
Sjouke Burry
Have you any idea?
At least, make it differential,one wire shielded from the moving air,
the other not,that gives you temperature compensation,and less
dependancy on the type of wire.Feed both wires with a current source,
and measure the voltage difference between them.
Burry.
Jim Thompson
Burry.
Works with thermistors as well. I did such in my Bachelor's thesis on
blood flow measurement with catheter-mounted thermistors (MIT/Harvard
Med School/Peter Bent Brigham Hospital, 1962).
...Jim Thompson
jacub
...Jim Thompson
Have You any example schematic or some materials?
jacub
Burry.
The best results I should achieve when I'll use a platinum wire, but I
have a problem to get this wire.
John Woodgate
Nichrome wire is not costly and is easily obtained. It is durable even
when red hot, as in electric heaters.
The disadvantage of Nichrome is that its resistance varies very much
less with temperature than that of platinum. But you may get enough
variation for your purpose.
Jim Thompson
I've got a schematic, but it's Germanium transistors ;-)
...Jim Thompson
Barry Lennox
Have you any idea?
There was the dual metal ball one that was in the Nov 95 issue of
"Scientific American" A number of folk got good results from these,
and claimed accuracy of a few % and resolution of better than 0.1m/s.
However it operates off 9 volts. DC-DC switcher?
Don Lancaster
Have you any idea?
We have two real ones up on eBay.
Many thanks,
Don Lancaster voice phone: (928)428-4073
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
rss: http://www.tinaja.com/whtnu.xml email: [email protected]
Please visit my GURU's LAIR web site at http://www.tinaja.com
Rich, Under the Affluence
IOW, if you could afford platinum wire, you could afford to hire
somebody to tell you how windy it is? ;-D
Cheers!
Rich
