Another LED question
Bounty
Nov 25, 2013
11
First of all I want to thank you for helping me with my previous LED problem. It works like a charm :)
I have 3x 27ohm resistors left unused from last thing i 'built'. The questions is can I use these 3x resistors for another project?
I would like to use only two blue LED diodes on any source.
Can I somehow make a circuit that includes 2x blue LED diodes and up to 3x 27ohm resistors? Or maybe 3x diodes or anything similar..
I tried calculating the values on the LED circuit calculators but I couldn't find anything to do with these three resistors.
Thanks again.
14,311
The idea of finding a circuit just for using up available components sounds a bit unconventional.
This won't work. Your choices of source are limited by the components at hand.
Here's one example how you can use your components:
attachment.php
(Note: NSPW500S is only a placeholder for your LEDs)
Each LED drops approx. 4V. Let's assume a current of 10mA throught each LED.
10mA will drop 0.27V on each of R1 and R2. Current through R3 will be 2*10mA, therefore voltage drop across R3 is 0.54V.
The total voltage across R3-R1-D1 (or R3-R2-D2, which is the same) will be
4V (D1)+0.27V (R1)+0.54V (R3) = 4.81V.
Therefore you could operate this circuit comfortably from 5V (e.g. USB power) or from 4.5V-6V with some variation in current.
