Anti-Taser clothes.
Skybuck Flying
The Netherlands is also introducing the "taser-gun".
To protect ourselfes from unnecessary deaths "anti-taser cloths" would be
nice ;)
What would be required for anti-taser clothes ?
Metal/Iron stuffings ? ;)
Bye,
Skybuck.
Tim Williams
nice ;)
Bye,
Skybuck.
They already make stainless-steel-fiber faraday jackets (worn by high
tension line workers, the kind that get a helicopter ride to work).
Good old chain mail and metal armor would both work as well.
Tim
Skybuck Flying
Metal/Iron conducts electricity... so that doesn't sound so good ;)
On the other hand it's hard material... tasers seem to work with needles
that need to penetrate something first.
However maybe very hard plastics that don't (or hardly) conduct any
eletricity would be a better/safer bet ;)
In case tasers get some kind of sticky plugs or so ;)
However then again 40.000 to 60.000 volts seem quite a lot...
Maybe under such circumstances even plastics becomes conductive ?
Bye,
Skybuck.
Paul E. Schoen
I did not realize that the taser fires two pointed electrodes and
administers a special waveform designed to cause involuntary muscle
contractions that effectively immobilize an assailant. I found this
reference from the Wiki: http://www.spectrum.ieee.org/dec07/5731
It seems that highly conductive clothing might render the device less
effective by essentially shorting the output, which must be current limited
to something like 20 to 100 mA. I can't imagine it being able to supply
more than about 100 watts, which would be only 2 mA at 50kV. Perhaps it
uses a series of high power, short duration bursts. But if conductive
clothing would have a resistance of perhaps 100 ohms between any two likely
points of entry of the darts, then it would take one amp to get 100 volts.
However, if the darts have only a small exposed conductive tip, and good
insulation that also penetrates the skin, conductive clothing would not
help. But I doubt the darts would penetrate even 20 gauge steel, and if
your armor is grounded then you would be protected in case one dart sticks
to it and the other lands on the ground.
Maybe some means of automatically sensing the location of the insertion,
and then having a robotically controlled wire cutter deployed to sever the
wires, might be the way to go.
Another deterent to anyone attempting to use a taser might be to wear a
vest of explosives and electrically controlled detonators. You would be
blown up, but it would also take out whoever tased you, and his buddies.
Paul
Sylvia Else
Paul said:
Bad idea.
Odd are a Taser won't kill a healthy person. I don't know how your
police force is trained, but over here, if the Taser proves to be
ineffective, the police will escalate as needed to subdue the subject.
If that means putting a couple of 9mm rounds in them, so be it.
Rather than having it come to that, "Please! Tase me bro!"
Which would be fine if police were only allowed to use a taser on a
person whom they could otherwise justifiably shoot. But we've clearly
seen tasers being used in situations where the victim is merely being
uncooperative. And some deaths have resulted.
Sylvia.
