Any electronics experts from South Africa?
Status
Not open for further replies.
benjaminpetrus
Dec 20, 2014
6
Hi! Are there any electronics experts from South Africa that can teach me about electronics?
[Moderator edit: I've "assisted you" with your English -- KrisBlueNZ]
hvacpw
Dec 19, 2014
3
Hi....I can Help you please tell me what is the problem related electronics.
benjaminpetrus
Dec 20, 2014
6
555 timer. No pins conected exept vcc and ground. Pin 3 shows volts. Must pin 3 not be dead
Merlin3189
Aug 4, 2011
250
Pin 3 output should be low, but there is a transistor beween pin 3 and ground, so there will be a small saturation voltage on it. That will only be about 0.1V unless you pass current into it.
Also you should connect trigger, threshold and reset to Vcc to ensure that the output is low. I think that is the default state, but it is not good to allow inputs to float.
Status
