Any Fritzing users? Can you help explain whats going on?
Stese
Dec 27, 2013
27
Hi all,
I've been attempting to use Fritzing to design a circuit I want to put onto a PCB in the future.
I've set up the breadboard view to replicate my real-world breadboard, and i'm happy with it.
Going into the PCB view. I've located the items roughly where I want them on the board, and have started to work on putting in the traces, whoever, i'm finding the Ratnest traces don't seem to match the breadboard at all... and I don't know why,
https://www.dropbox.com/s/u9gfn1giuy6we2e/RSTD Breakout.fzz?dl=0
is the file i've saved ,and i'm running 0.9.0 x64.
This file is showing a ratsnest line on the second MCP23017 chip between pins A1 and A2, which isn't needed. PCB does not have this connection shown at all, (but there is a ratsnest for it) Schematic view is completely empty, as i've read it can confuse matters.
I've asked the question on the Fritzing forum, but i've not had any replies yet... :(
Hope someone here can help,
Regards,
Steve
ketanrd01
Aug 11, 2014
74
I have used it before and suggest you against using it Stese.
Try Eagle or ExpressPCB instead.
ketanrd01
Aug 11, 2014
74
Also, if you have any other problem, tell me.
I could send you a layout of your ckt if you want the same.....
Stese
Dec 27, 2013
27
Hi Ketanrd01,
Thanks for the advice, I'll have a look. I'm using fritzing as it's got the breadboard view I like to work in, and also already has parts available that I need. I've found that other programs either tend not to have the parts i'm using, or make it very difficult to create new parts.
Regards,
Steve
