Any tips on using these crimps?
Braeden Hamson
Feb 18, 2016
240
Hey guys,
I bought some of these crimps (see attached) which I'm putting into these housings.
http://www.digikey.com/product-deta...E2omT_FOUQGxMlLtnedSOYw4q1VU1ORkh4aAgpn8P8HAQ
(MF PN 22-02-3037)
These housings were recommended by Digikey to work with the crimps I bought and for the most part they do. My trouble is the bits of metal between the crimps. It seems they're designed to be separated at the circle between them. However that leaves a really big bit of metal on my crimp. Which obviously doesn't fit into my housing. So what do I do? I have a handy pair of D-sub crimpers which are a gift from the divines as far as I'm concerned. And I've tried to bend the tabs up with those but that just ruins the crimp. I can cut the tabs off with a pair of flush cuts, but I can tell that's gonna dull them quick and its really tedious.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,968
These crimp terminals are mounted on a reel strip intended to feed and position (that's what the holes are for between terminals attached to the reel strip) each terminal for automatic crimping and subsequent separation from the strip by a shear cutter... all at a speed faster than the eye can follow.
You will need a pair of flush-cutting diagonal pliers with carbide blades to separate the terminal from the strip for crimping by hand with the proper roll-crimp tool. It would be better to buy the crimp terminals loosely packaged instead of attached to a reel strip... that's probably too late now, but I bet you got them at a good price. You MUST use carbide cutters and a good set is expensive compared to steel cutters.
Braeden Hamson
Feb 18, 2016
240
Thank you sir!
I figured I had the wrong tools, I just wanted to be sure there wasn't some super easy way. And carbide cutters aren't cheap... Makes me want to make my own using lathe cutter inserts. That'd be a project.
Braeden Hamson
Feb 18, 2016
240
I actually found a nice little trick by myself. The crimps I bought have cutters behind the axis. They'll trim the excess metal between the crimps really well. I think that's why it's there. I thought it was just for cutting wires.
