ANYONE HAS A VHDL CODE EXAMPLE FOR A PHERIPHERAL DEVICE INTERFACE TO A PC PARALLEL PORT(ECP)
LRCR
I need a VHDL code example of a Peripheral interface that will
communicate to a PC Parallel Port. The Mode of this Port
communication is ECP. Any help will be appreciated.
K
krw
Ah, senior projects are due.
LRCR
No,
This may seem to be a school senior project, but it is not. I am an
analog designer trying to get into more on VHDL. The job at present
is giving me an opportunity to start with the little VHDL experience I
have. I would appreciate any help you can provide. The Yahoo and
google search engine provide some help, but not enough on ECP mode.
From your comment, "Ah, senior projects are due", it seems that this
is an easy VHDL design for you. If so, can you help?
CAESAR
James Beck
No,
CAESAR
You might try starting with learning about the PC's parallel port. I
liked the book "Parallel Port Complete" by Jan Axelson. You can get it
at amazon.com . You can also look at some of the beginning VHDL books
they have. Xilinx and Altera both have pretty reasonably priced
development kits that you can use to get your feet wet.
Jim
Rich Grise
No,
Well, I found a pretty good spec, but it's kind of wordy:
http://www.fapo.com/files/ecp_reg.pdf
And, FYI, bottom-posting is the convention here. :)
Good Luck!
Rich
K
Keith
No,
Ok, it is that time of year. ;-)
I am an analog designer trying to get into more on VHDL.
deity. help us. Joerg, Jim, listening? ;-)
The job at present
How about this: http://www.beyondlogic.org/ecp/ecp.htm
I've not interfaced to a printer in ECP mode but it looks pretty
straight forward. Shouldn't be too much trouble. Sure, I think I
can help. It's likely others will join the fun too.
Jim Thompson
[snip]
When I need logic more advanced than simple combinational (like a PCI
bus) I hire it done ;-)
...Jim Thompson
LRCR
Thanks for the help. I'll give this website a try.
Caesar
LRCR
Thanks for your feedback
Caesar
[snip]
...Jim Thompson
K
krw
[snip]
Are you saying that PCI is simple, or you need something more
advanced than simple (example of not simple).
....besides, we do the much the same with analog trivia. ;-)
K
krw
If you need some help, do tell us more of the requirements. The
design should be quite easy, but without requirements all you'll
get is another level of crap to interface to (ECP looks trivial).
Michael
For the nitty-gritty on ECP mode itself (or any other parallel port mode, for
that matter), you might want to check out Jan Axelson's site, LVR.COM. Seems to
me she also offers RS-232 and USB tutorials. Very good stuff, all.
LRCR
Sure,
From reading the ECP.pdf document,the data lines is shared for both
data and command (referred as data cycle or command cycle). Line
HostAck is used to determine the cycle.
On the command cycle, 2 format is possible. One format is RLE and the
other is address. Bit 7 is used to determined which format is
selected. RLE will not be used in this application. Only the Address
part is used. With 7 bits, I can used up to 128 address to select
different function internal to the Altera FPGA. Also, in the command
cycle, the data line will flow only in one direction(PC to my
peripheral device).
On the Data cycle, both direction on the data line will be used.
There are 3 different function the FPGA will perform. Let call these
function A, B, C and D.
Function A (Write Only, PC to Device)
First, the PC Parallel Port will address the FPGA for function A. Then
loads via Data cycle, 2 bytes in the FPGA. The two bytes will appear
on 16 pins of the FPGA. The a CS strobe is pulsed on a separate pin
of the FPGA.
Function B (Write Only, PC to Device)
The PC Parallel Port will address the FPGA for function B. Then loads
via Data cycle, 1 bytes into the FPGA. The 1 byte is then clocked out
of the FPGA serially at 2 MHz as a SPI interface.
Function C (Write Only, PC to Device)
The PC Parallel Port will address the FPGA for function C. Then loads
via Data cycle, 1 bytes into the FPGA. Each bits of this byte will
control the direction of the pins of funtion D.
Function D (Write and Read, PC to Device or Device to PC)
WRITE OPERATION:
The PC Parallel Port will address the FPGA for function D, Write
operation. Then loads via Data cycle, 1 bytes into the FPGA.
Depending on the control bits of function C, some or all of the bit of
the loaded bytes will appear on up to 8 output pins of the FPGA.
READ OPERATION:
The PC Parallel Port will address the FPGA for function D, READ
operation. The FPGA will read the same 8 pin described above for the
WRITE operation and is then transferred to the data lines of the PC
Parallel Port . The PC then reads the 8 bit data.
As I see it, I will be OK with the Function part of the FPGA. But,
however simple the Parallel Port is in this application, I need help
on the Parallel communication protocol part. That is, how to make
the data available to and from the FPGA functional part.
CAESAR
K
Keith
Sure,
peripheral device).
Good so far. Note that I've never used an Altera FPGA, so there
may be differences in the implementations.
Ok, I suspected that. ;-)
of the FPGA.
Questions:
The 'CS' is strobed after the second byte appears?
How long is CS?
Is handshaking on CS required?
Do the two bytes have to appear at the output at the same time or
can they appear at any time before CS?
Separate output from Function A?
Addresses?
How do I know the difference between Function A and Function B?
2MHz, where? Do you have an oscillator? What frequency?
What about overruns/underruns? Frameing?
Simple enough.
WRITE OPERATION:
Looks simple.
READ OPERATION:
Direction bits? Does this read read back the bits written (and set
to output) in D-Write above?
That's pretty easy. When the port is writing to the FPGA you set
the FPGA drivers to 'Z'. When reading the FPGA they're driven by
the input pins on your Function D-Read port. Something like:
ParallelPort <= PortD
WHEN FunctionD_Read = '1'
ELSE (others=>'Z');
This may have timing problems so depending on Altera's I/O you
should incorporate a flipflop into the I/O cell (at least with
Xilinx this works better):
PPort: PROCESS (Clock, Reset)
BEGIN
IF Reset = '1'
THEN
ParallelPort <= (others=>'Z');
ELSIF Rising_edge(Clock)
THEN
IF FunctionD_Read = '1'
THEN
ParallelPort <= PortD;
ELSE
END IF;
END IF;
END PROCESS;
