Anyone has schematic of ANY printer with USB port ?
Externet
Aug 24, 2009
944
Hi.
If you have a schematic of ANY printer with USB port; can you please check if 5V is provided at its jack ?
14,312
I don't have a schematic, but I think it is unlikely that 5 V are present at the printer's USB port as the printer is a USB device. Only USB hosts provide power to USN devices, not vice versa.
Power on a USB port will be available if the printer has a USB port to handke e.g. USB sticks to print directly from stick etc. In that case the printer is the host.
14,312
The list of known compatible printers is surprisingly (?) rather small.
Follow your link, goto page 2 and look under "Power": a separate power adapter is required (and should be supplied with the USB dongle). That's where it gets power from, not from the USB port.
Externet
Aug 24, 2009
944
Thanks. Missed that on the linked page. Previously I looked at another information page about the gadget. Found two more brands for the same application, also belly up, unobtanium.
I believed a plain wifi dongle fed with 5V at the printer port should do the bridging...
