Anyone Have Spice Model for LM134/334 ??
Jim Thompson
Thanks!
...Jim Thompson
James Meyer
Thanks!
...Jim Thompson
Probably not. The LM134 was designed so long ago that it was probably
done the way God intended, with a pencil, pad of paper, and a slide rule.
Spice models are a crutch for the uninformed or unimaginative engineer.
Jim ":cool: <--- obligatory smile" Meyer
K
Kevin Aylward
rule.
engineer.
I hope that was a joke, or your completely out to lunch. Like, you try
designing a 1000 transistor analogue i.c and expect that $100k mask set
not to be toilet paper.
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
SuperSpice, a very affordable Mixed-Mode
Windows Simulator with Schematic Capture,
Waveform Display, FFT's and Filter Design.
H
Helmut Sennewald
Thanks!
Hello Jim,
I have written a SPICE model for the LM334 some time ago.
Therefore I simply copied the schematic from the datasheet and
guessed the size and parameters of the transistors.
I have never done measurements on a real LM334.
I have made some times ago a model for the members of the
LTspice group. The model and a symbol can be only downloaded
from here:
http://groups.yahoo.com/group/LTspice/
Files > Lib > LM334 Current Source LM334.sub, LM334.asy
Best regards,
Helmut
Moderator of the LTspice Yahoo-group
EN
... snip ...
Here's an old list I got from Nat Semi, from 5" floppy,
* Library of National Semiconductor Corp. BIPOLAR OP-AMP
* Macromodels. Version 2.5
* This library of macromodels is being supplied to users as
* an aid to circuit designs. While it reflects reasonably
* close similarity to the actual device in terms of
* performance, it is not suggested as a replacement for
* breadboarding. Simulation should be used as a supplement
* to traditional lab testing.
* Users should very carefully note the following factors
* regarding these models:
* -- Model performance in general will reflect typical
* baseline specs for a given device, and certain aspects of
* performance may not be modeled fully.
* -- While reasonable care has been taken in their
* preparation, we cannot be responsible for correct
* application on any and all computer systems.
* -- Model users are hereby notified that these models are
* supplied "as is", with no direct or implied responsibility
* on the part of National Semiconductor for their operation
* within a customer circuit or system. Further, National
* Semiconductor reserves the right to change these models
* without prior notice.
* -- In all cases, the current data sheet information for a
* given real device is your final design guideline, and is
* the only actual performance guarantee. For further
* technical information, refer to individual device data
* sheets.
* Note: The current models presently do not simulate
* temperature or noise effects.
* Your feedback and suggestions on these (and future) models
* will be appreciated.
* Models developed by:
* David Hindi
* National Semiconductor For information on the models, contact:
* 2900 Semiconductor Dr. Linear Applications
* Santa Clara, CA 95052 (408) 721-3877
* M/S C2500
* FAX (408) 721-7321 For ordering information, contact:
* Customer Response Center
* (408) 721-4902
*LM118 OPERATIONAL AMPLIFIER MACRO-MODEL
* connections: non-inverting input
* | inverting input
* | | positive power supply
* | | | negative power supply
* | | | | output
..SUBCKT LM118 1 2 99 50 28
*Features:
*Internal frequency compensation
*High bandwidth = 15MHz
*Minimum slew rate = 50V/uS
*Low bias current = 250nA
*Wide supply range = +-5V to +-20V
****************INPUT STAGE**************
IOS 2 1 6N
*^Input offset current
R1 1 3 1.5MEG
R2 3 2 1.5MEG
I1 4 50 100U
R3 99 5 517
R4 99 6 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=25 MHz
C4 5 6 6.1569P
***********COMMON MODE EFFECT***********
I2 99 50 4.9M
*^Quiescent supply current
EOS 7 1 POLY(1) 16 49 4E-3 1
*Input offset voltage.^
R8 99 49 80.2K
R9 49 50 80.2K
*********OUTPUT VOLTAGE LIMITING********
V2 99 8 2.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.63
**************SECOND STAGE**************
EH 99 98 99 49 1
G1 98 9 POLY(1) 5 6 0 3.0967E-4 0 596.674E-3
*Fp1=115 Hz
R5 98 9 9.6877G
C3 98 9 1.4286P
************POLE/ZERO STAGE*************
*Fp=300 KHz, Fz=600 KHz
G2 98 13 9 49 1E-6
R10 98 13 1MEG
R11 98 14 1MEG
C6 14 13 2.6526E-13
***************POLE STAGE***************
*Fp=55 MHz
G3 98 15 13 49 1E-6
R12 98 15 1MEG
C5 98 15 2.8937E-15
*********COMMON-MODE ZERO STAGE*********
*Fpcm=3 KHz
G4 98 16 3 49 1E-8
L2 98 17 53.1M
R13 17 16 1K
**************OUTPUT STAGE**************
F6 50 99 POLY(1) V6 200U 1
E1 99 23 99 15 1
R16 24 23 30
D5 26 24 DX
V6 26 22 .63V
R17 23 25 30
D6 25 27 DX
V7 22 27 .63V
C9 23 22 100P
V5 22 21 0.2V
D4 21 15 DX
V4 20 22 0.2V
D3 15 20 DX
L3 22 28 100P
RL3 22 28 100K
***************MODELS USED**************
..MODEL DX D(IS=1E-15)
..MODEL QX NPN(BF=333.333)
..ENDS
*LM124 Low Power Quad OPERATIONAL AMPLIFIER MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM124 1 2 99 50 28
*Features:
*Eliminates need for dual supplies
*Large DC voltage gain = 100dB
*High bandwidth = 1MHz
*Low input offset voltage = 2mV
*Wide supply range = +-1.5V to +-16V
*NOTE: Model is for single device only and simulated
* supply current is 1/4 of total device current.
* Output crossover distortion with dual supplies
* is not modeled.
IOS 2 1 3N
R1 1 3 500K
R2 3 2 500K
I1 99 4 100U
R3 5 50 517
R4 6 50 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=1.2 MHz
C4 5 6 128.27P
I2 99 50 75U
EOS 7 1 POLY(1) 16 49 1E-3 1
R8 99 49 60K
R9 49 50 60K
V2 99 8 1.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 0.635
EH 99 98 99 49 1
G1 98 9 POLY(1) 5 6 0 9.8772E-4 0 .3459
*Fp1=7.86 Hz
R5 98 9 101.2433MEG
C3 98 9 200P
*Fp=2 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 7.9577E-14
*Fpcm=10 KHz
G4 98 16 3 49 5.6234E-8
L2 98 17 15.9M
R13 17 16 1K
F6 50 99 POLY(1) V6 300U 1
E1 99 23 99 15 1
R16 24 23 17.5
D5 26 24 DX
V6 26 22 .63V
R17 23 25 17.5
D6 25 27 DX
V7 22 27 .63V
V5 22 21 0.27V
D4 21 15 DX
V4 20 22 0.27V
D3 15 20 DX
L3 22 28 500P
RL3 22 28 100K
..MODEL QX PNP(BF=1.111E3)
..ENDS
*LM158 DUAL OPERATIONAL AMPLIFIER MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM158 1 2 99 50 28
*Features:
* supply current is 1/2 of total device current.
* is not modeled.
IOS 2 1 5N
R1 1 3 500K
R2 3 2 500K
I1 99 4 100U
R3 5 50 517
R4 6 50 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=1.2 MHz
C4 5 6 128.27P
I2 99 50 75U
EOS 7 1 POLY(1) 16 49 2E-3 1
R8 99 49 60K
R9 49 50 60K
V2 99 8 1.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 .635
EH 99 98 99 49 1
*Fp1=7.86 Hz
R5 98 9 101.2433MEG
C3 98 9 200P
*Fp=2 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 7.9577E-14
*Fpcm=10 KHz
L2 98 17 15.9M
R13 17 16 1K
E1 99 23 99 15 1
R16 24 23 17.5
D5 26 24 DX
V6 26 22 .63V
R17 23 25 17.5
D6 25 27 DX
V7 22 27 .63V
V5 22 21 0.27V
D4 21 15 DX
V4 20 22 0.27V
D3 15 20 DX
L3 22 28 500P
RL3 22 28 100K
..ENDS
*LM218 OPERATIONAL AMPLIFIER MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM218 1 2 99 50 28
*Features:
IOS 2 1 6N
R1 1 3 1.5MEG
R2 3 2 1.5MEG
I1 4 50 100U
R3 99 5 517
R4 99 6 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=25 MHz
C4 5 6 6.1569P
I2 99 50 4.9M
R8 99 49 80.2K
R9 49 50 80.2K
V2 99 8 2.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.63
EH 99 98 99 49 1
*Fp1=115 Hz
R5 98 9 9.6877G
C3 98 9 1.4286P
G2 98 13 9 49 1E-6
R10 98 13 1MEG
R11 98 14 1MEG
C6 14 13 2.6526E-13
*Fp=55 MHz
G3 98 15 13 49 1E-6
R12 98 15 1MEG
C5 98 15 2.8937E-15
*Fpcm=3 KHz
G4 98 16 3 49 1E-8
L2 98 17 53.1M
R13 17 16 1K
E1 99 23 99 15 1
R16 24 23 30
D5 26 24 DX
V6 26 22 .63V
R17 23 25 30
D6 25 27 DX
V7 22 27 .63V
C9 23 22 100P
V5 22 21 0.2V
D4 21 15 DX
V4 20 22 0.2V
D3 15 20 DX
L3 22 28 100P
RL3 22 28 100K
..ENDS
*LM224 Low Power Quad OPERATIONAL AMPLIFIER MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM224 1 2 99 50 28
*Features:
* is not modeled.
IOS 2 1 3N
R1 1 3 500K
R2 3 2 500K
I1 99 4 100U
R3 5 50 517
R4 6 50 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=1.2 MHz
C4 5 6 128.27P
I2 99 50 75U
R8 99 49 60K
R9 49 50 60K
V2 99 8 1.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 .635
EH 99 98 99 49 1
*Fp1=7.86 Hz
R5 98 9 101.2433MEG
C3 98 9 200P
*Fp=2 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 7.9577E-14
*Fpcm=10 KHz
L2 98 17 15.9M
R13 17 16 1K
E1 99 23 99 15 1
R16 24 23 17.5
D5 26 24 DX
V6 26 22 .63V
R17 23 25 17.5
D6 25 27 DX
V7 22 27 .63V
V5 22 21 0.27V
D4 21 15 DX
V4 20 22 0.27V
D3 15 20 DX
L3 22 28 500P
RL3 22 28 100K
..ENDS
*LM258 DUAL OPERATIONAL AMPLIFIER MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM258 1 2 99 50 28
*Features:
* is not modeled.
IOS 2 1 5N
R1 1 3 500K
R2 3 2 500K
I1 99 4 100U
R3 5 50 517
R4 6 50 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=1.2 MHz
C4 5 6 128.27P
I2 99 50 75U
R8 99 49 60K
R9 49 50 60K
V2 99 8 1.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 .635
EH 99 98 99 49 1
*Fp1=7.86 Hz
R5 98 9 101.2433MEG
C3 98 9 200P
*Fp=2 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 7.9577E-14
*Fpcm=10 KHz
L2 98 17 15.9M
R13 17 16 1K
E1 99 23 99 15 1
R16 24 23 17.5
D5 26 24 DX
V6 26 22 .63V
R17 23 25 17.5
D6 25 27 DX
V7 22 27 .63V
V5 22 21 0.27V
D4 21 15 DX
V4 20 22 0.27V
D3 15 20 DX
L3 22 28 500P
RL3 22 28 100K
..ENDS
*LM318 OPERATIONAL AMPLIFIER MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM318 1 2 99 50 28
*Features:
IOS 2 1 30N
R1 1 3 1.5MEG
R2 3 2 1.5MEG
I1 4 50 100U
R3 99 5 517
R4 99 6 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=25 MHz
C4 5 6 6.1569P
I2 99 50 4.9M
R8 99 49 80.2K
R9 49 50 80.2K
V2 99 8 2.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.63
EH 99 98 99 49 1
*Fp1=115 Hz
R5 98 9 9.6877G
C3 98 9 1.4286P
G2 98 13 9 49 1E-6
R10 98 13 1MEG
R11 98 14 1MEG
C6 14 13 2.6526E-13
*Fp=55 MHz
G3 98 15 13 49 1E-6
R12 98 15 1MEG
C5 98 15 2.8937E-15
*Fpcm=3 KHz
G4 98 16 3 49 1E-8
L2 98 17 53.1M
R13 17 16 1K
E1 99 23 99 15 1
R16 24 23 30
D5 26 24 DX
V6 26 22 .63V
R17 23 25 30
D6 25 27 DX
V7 22 27 .63V
C9 23 22 100P
V5 22 21 0.2V
D4 21 15 DX
V4 20 22 0.2V
D3 15 20 DX
L3 22 28 100P
RL3 22 28 100K
..ENDS
*LM324 Low Power Quad OPERATIONAL AMPLIFIER MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM324 1 2 99 50 28
*Features:
* is not modeled.
IOS 2 1 5N
R1 1 3 500K
R2 3 2 500K
I1 99 4 100U
R3 5 50 517
R4 6 50 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=1.2 MHz
C4 5 6 128.27P
I2 99 50 75U
R8 99 49 60K
R9 49 50 60K
V2 99 8 1.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 .635
EH 99 98 99 49 1
*Fp1=7.86 Hz
R5 98 9 101.2433MEG
C3 98 9 200P
*Fp=2 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 7.9577E-14
*Fpcm=10 KHz
L2 98 17 15.9M
R13 17 16 1K
E1 99 23 99 15 1
R16 24 23 17.5
D5 26 24 DX
V6 26 22 .63V
R17 23 25 17.5
D6 25 27 DX
V7 22 27 .63V
V5 22 21 0.27V
D4 21 15 DX
V4 20 22 0.27V
D3 15 20 DX
L3 22 28 500P
RL3 22 28 100K
..ENDS
*LM358 DUAL OPERATIONAL AMPLIFIER MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM358 1 2 99 50 28
*Features:
* is not modeled.
IOS 2 1 5N
R1 1 3 500K
R2 3 2 500K
I1 99 4 100U
R3 5 50 517
R4 6 50 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=1.2 MHz
C4 5 6 128.27P
I2 99 50 75U
R8 99 49 60K
R9 49 50 60K
V2 99 8 1.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 .635
EH 99 98 99 49 1
*Fp1=7.86 Hz
R5 98 9 101.2433MEG
C3 98 9 200P
*Fp=2 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 7.9577E-14
*Fpcm=10 KHz
L2 98 17 15.9M
R13 17 16 1K
E1 99 23 99 15 1
R16 24 23 17.5
D5 26 24 DX
V6 26 22 .63V
R17 23 25 17.5
D6 25 27 DX
V7 22 27 .63V
V5 22 21 0.27V
D4 21 15 DX
V4 20 22 0.27V
D3 15 20 DX
L3 22 28 500P
RL3 22 28 100K
..ENDS
*LM607/LM607A/LM607B OPERATIONAL AMPLIFIER MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM607 1 2 99 50 28
*Features:
*Low Vos = 25 uV
*High gain = 134 dB
*High unity gain freq. = 1.8MHz
*High slew rate = .7V/uS
*Wide supply range = +-3V to +-18V
*NOTE: Noise is not modeled.
IOS 2 1 500P
R1 1 3 1MEG
R2 3 2 1MEG
I1 4 50 100U
R3 5 99 517
R4 6 99 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=14 MHz
C4 5 6 10.994P
I2 99 50 900UA
EOS 7 1 POLY(1) 16 49 15E-6 1
R8 99 49 2MEG
R9 49 50 2MEG
V2 99 8 1.83
D1 9 8 DX
D2 10 9 DX
V3 10 50 1.83
EH 99 98 99 49 1
G1 98 9 5 6 2E-3
*Fp1=.14 Hz
R5 98 9 5.116G
C3 98 9 222.222P
*Fp=500 KHz, Fz=800 KHz
G2 98 13 9 49 1E-6
R10 98 13 1MEG
R11 98 14 1.666MEG
C5 14 13 1.194E-13
*Fp=14 MHz
G3 98 15 13 49 1E-6
R12 98 15 1MEG
C6 98 15 1.1368E-14
*Fpcm=200 Hz
G4 98 16 3 49 1E-10
L2 98 17 795.8M
R13 17 16 1K
F6 50 99 POLY(1) V6 80U 1
E1 99 23 99 15 1
R16 24 23 50
D5 26 24 DX
V6 26 22 0.65V
R17 23 25 50
D6 25 27 DX
V7 22 27 0.65V
V5 22 21 0.145V
D4 21 15 DX
V4 20 22 0.145V
D3 15 20 DX
L3 22 28 500P
RL3 22 28 100K
..MODEL QX NPN(BF=5.0E4)
..ENDS
*LM627 PRECISION OPERATIONAL AMPLIFIER MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM627 1 2 99 50 28
*Features:
*Low Vos = 25 uV
*High gain = 134 dB
*High unity gain freq. = 14 MHz
*High slew rate = 4.5V/uS
*Wide supply range = +-3.5V to +-18V
IOS 2 1 2N
R1 1 3 10G
R2 3 2 10G
I1 4 50 100U
R3 5 99 517
R4 6 99 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=25.3 MHz
C4 5 6 6.084P
I2 99 50 2.9MA
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.83
D1 9 8 DX
D2 10 9 DX
V3 10 50 1.83
EH 99 98 99 49 1
G1 98 9 5 6 2.1E-3
*Fp1=1.49 Hz
R5 98 9 4.807G
C3 98 9 22.2222P
*Fp=300 KHz, Fz=1 MHz
G2 98 13 9 49 1E-6
R10 98 13 1MEG
R11 98 14 428.571K
C5 14 13 3.7136E-13
*Fp=30 MHz
G3 98 15 13 49 1E-6
R12 98 15 1MEG
C6 98 15 5.305E-15
*Fpcm=300 Hz
G4 98 16 3 49 1E-10
L2 98 17 530.5M
R13 17 16 1K
F6 50 99 POLY(1) V6 220U 1
E1 99 23 99 15 1
R16 24 23 50
D5 26 24 DX
V6 26 22 0.63V
R17 23 25 50
D6 25 27 DX
V7 22 27 0.63V
V5 22 21 1.4V
D4 21 15 DX
V4 20 22 1.4V
D3 15 20 DX
L3 22 28 500P
RL3 22 28 100K
..MODEL QX NPN(BF=1.6667E4)
..ENDS
*LM637 PRECISION OPERATIONAL AMPLIFIER MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM637 1 2 99 50 28
*Features:
*Low Vos = 25 uV
*High gain = 134 dB
*High unity gain freq. = 65 MHz
*High slew rate = 14V/uS
IOS 2 1 2N
R1 1 3 10G
R2 3 2 10G
I1 4 50 100U
R3 5 99 517
R4 6 99 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=50 MHz
C4 5 6 3.0784P
I2 99 50 2.9MA
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.83
D1 9 8 DX
D2 10 9 DX
V3 10 50 1.83
EH 99 98 99 49 1
G1 98 9 5 6 3.7E-3
F1 9 98 POLY(1) VA3 0 0 0 9.24E7
*Fp1=10 Hz
R5 98 9 2.7056G
C3 98 11 5.8824P
VA3 9 11 0
*Fp=300 KHz, Fz=450 KHz
G2 98 13 9 49 1E-6
R10 98 13 1MEG
R11 98 14 2MEG
C6 14 13 1.768E-13
***************POLE STAGE****************
*Fp=50 MHz
G3 98 15 13 49 1E-6
R12 98 15 1MEG
C5 98 15 3.1831E-15
*Fp=80 MHz
G5 98 18 15 49 1E-6
R14 98 18 1MEG
C7 98 18 1.9894E-15
*Fpcm=2 KHz
G4 98 16 3 49 1E-10
L2 98 17 79.6M
R13 17 16 1K
E1 99 23 99 18 1
R16 24 23 50
D5 26 24 DX
V6 26 22 0.61V
R17 23 25 50
D6 25 27 DX
V7 22 27 0.61V
V5 22 21 1.4V
D4 21 18 DX
V4 20 22 1.4V
D3 18 20 DX
L3 22 28 .02U
RL3 22 28 100K
..MODEL QX NPN(BF=1.67E4)
..ENDS
*LM741/A/C/E OPERATIONAL AMPLIFIER MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM741 1 2 99 50 28
*Features:
*Improved performance over industry standards
*Plug-in replacement for LM709,LM201,MC1439,748
*Input and output overload protection
IOS 2 1 20N
R1 1 3 250K
R2 3 2 250K
I1 4 50 100U
R3 5 99 517
R4 6 99 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=2.55 MHz
C4 5 6 60.3614P
I2 99 50 1.6MA
R8 99 49 40K
R9 49 50 40K
V2 99 8 1.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 1.63
EH 99 98 99 49 1
G1 98 9 5 6 2.1E-3
*Fp1=5 Hz
R5 98 9 95.493MEG
C3 98 9 333.33P
*Fp=30 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 5.3052E-15
*Fpcm=300 Hz
G4 98 16 3 49 3.1623E-8
L2 98 17 530.5M
R13 17 16 1K
F6 50 99 POLY(1) V6 450U 1
E1 99 23 99 15 1
R16 24 23 25
D5 26 24 DX
V6 26 22 0.65V
R17 23 25 25
D6 25 27 DX
V7 22 27 0.65V
V5 22 21 0.18V
D4 21 15 DX
V4 20 22 0.18V
D3 15 20 DX
L3 22 28 100P
RL3 22 28 100K
..MODEL QX NPN(BF=625)
..ENDS
*LM2902 QUAD OPERATIONAL AMPLIFIER MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM2902 1 2 99 50 28
*Features:
* is not modeled.
IOS 2 1 5N
R1 1 3 500K
R2 3 2 500K
I1 99 4 100U
R3 5 50 517
R4 6 50 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=1.2 MHz
C4 5 6 128.27P
I2 99 50 75U
R8 99 49 60K
R9 49 50 60K
V2 99 8 1.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 .635
EH 99 98 99 49 1
*Fp1=7.86 Hz
R5 98 9 101.2433MEG
C3 98 9 200P
*Fp=2 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 7.9577E-14
*Fpcm=10 KHz
L2 98 17 15.9M
R13 17 16 1K
E1 99 23 99 15 1
R16 24 23 17.5
D5 26 24 DX
V6 26 22 .63V
R17 23 25 17.5
D6 25 27 DX
V7 22 27 .63V
V5 22 21 0.27V
D4 21 15 DX
V4 20 22 0.27V
D3 15 20 DX
L3 22 28 500P
RL3 22 28 100K
..ENDS
*LM2904 DUAL OPERATIONAL AMPLIFIER MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM2904 1 2 99 50 28
*Features:
* is not modeled.
IOS 2 1 5N
R1 1 3 500K
R2 3 2 500K
I1 99 4 100U
R3 5 50 517
R4 6 50 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=1.2 MHz
C4 5 6 128.27P
I2 99 50 75U
R8 99 49 60K
R9 49 50 60K
V2 99 8 1.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 .635
EH 99 98 99 49 1
*Fp1=7.86 Hz
R5 98 9 101.2433MEG
C3 98 9 200P
*Fp=2 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 7.9577E-14
*Fpcm=10 KHz
L2 98 17 15.9M
R13 17 16 1K
E1 99 23 99 15 1
R16 24 23 17.5
D5 26 24 DX
V6 26 22 .63V
R17 23 25 17.5
D6 25 27 DX
V7 22 27 .63V
V5 22 21 0.27V
D4 21 15 DX
V4 20 22 0.27V
D3 15 20 DX
L3 22 28 500P
RL3 22 28 100K
..ENDS
*LH4161 High Speed OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LH4161 1 2 99 50 28
*Features:
*Low supply current = 5mA
*High bandwidth = 50MHz
*High slew rate = 300V/uS
IOS 2 1 150N
CI1 1 0 1.5P
CI2 2 0 1.5P
R1 1 3 162.5K
R2 3 2 162.5K
I1 4 50 1M
R3 99 5 651.7
R4 99 6 651.7
Q1 5 2 45 QX
Q2 6 7 46 QX
R43 45 4 600
R44 46 4 600
*Fp2=200 MHz
C4 5 6 6.1054E-13
I2 99 50 4M
EOS 7 1 POLY(1) 16 49 .5E-3 1
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.335
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.155
EH 99 98 99 49 1
F1 9 98 POLY(1) VA1 0 0 0 20
G1 98 9 POLY(1) 5 6 0 2.9E-3 0 5.062E-4
*Fp1=23.52 KHz
R5 98 9 1MEG
C3 98 9 6.7668P
*Fp=203 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 7.84E-16
*Fpcm=200 KHz
G4 98 16 3 49 1.9952E-8
L2 98 17 795.77U
R13 17 16 1K
VA1 99 93 0
E1 93 23 99 15 1
R16 24 23 10
D5 26 24 DY
V6 26 22 .63V
R17 23 25 10
D6 25 27 DY
C9 23 22 500P
V7 22 27 .63V
V5 22 21 .63V
D4 21 15 DX
V4 20 22 .63V
D3 15 20 DX
L3 22 28 100P
RL3 22 28 100K
..MODEL DY D(IS=1E-25)
..MODEL QX NPN(BF=250)
..ENDS
*LH4162 High Speed OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LH4162 1 2 99 50 28
*Features:
IOS 2 1 150N
CI1 1 0 1.5P
CI2 2 0 1.5P
R1 1 3 162.5K
R2 3 2 162.5K
I1 4 50 1M
R3 99 5 651.7
R4 99 6 651.7
Q1 5 2 45 QX
Q2 6 7 46 QX
R43 45 4 600
R44 46 4 600
*Fp2=200 MHz
C4 5 6 6.1054E-13
I2 99 50 4M
EOS 7 1 POLY(1) 16 49 5E-3 1
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.335
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.155
EH 99 98 99 49 1
*Fp1=23.52 KHz
R5 98 9 1MEG
C3 98 9 6.7668P
*Fp=203 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 7.84E-16
*Fpcm=200 KHz
L2 98 17 795.77U
R13 17 16 1K
VA1 99 93 0
E1 93 23 99 15 1
R16 24 23 10
D5 26 24 DY
V6 26 22 .63V
R17 23 25 10
D6 25 27 DY
C9 23 22 500P
V7 22 27 .63V
V5 22 21 .63V
D4 21 15 DX
V4 20 22 .63V
D3 15 20 DX
L3 22 28 100P
RL3 22 28 100K
..ENDS
*LM6118/A Fast Settling Dual OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM6118 1 2 99 50 28
*Features:
*Low offset voltage = .2mV
*High bandwidth = 17MHz
*Slew rate (Av=-1) = 140V/uS
IOS 2 1 20N
CI1 1 0 2.5P
CI2 2 0 2.5P
R1 1 3 3.125G
R2 3 2 3.125G
I1 99 4 40U
R43 45 4 1.25K
R44 46 4 1.25K
Q1 5 2 45 QX
Q2 6 7 46 QX
R3 50 5 2.54K
R4 50 6 2.54K
*Fp2=30 MHz
C4 5 6 1.0433P
I2 99 50 2.71M
EOS 7 1 POLY(1) 16 49 .2E-3 1
R8 99 49 71.4K
R9 49 50 71.4K
V2 99 8 2.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.63
EH 99 98 99 49 1
G1 98 9 POLY(1) 5 6 0 5E-3 0 5.056
*Fp1=38.24 Hz
R5 98 9 100MEG
C3 98 9 41.62P
*Fp=110 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 1.4469E-15
*Fpcm=6 KHz
G4 98 16 3 49 1E-8
L2 98 17 26.526M
R13 17 16 1K
E1 99 23 99 15 1
R16 24 23 10
D5 26 24 DY
V6 26 22 .63V
R17 23 25 10
D6 25 27 DY
C9 23 22 .001U
V7 22 27 .63V
V5 22 21 .63V
D4 21 15 DX
V4 20 22 .63V
D3 15 20 DX
L3 22 28 100P
RL3 22 28 100K
..MODEL QX PNP(BF=100)
..ENDS
*LM6161 High Speed OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM6161 1 2 99 50 28
*Features:
IOS 2 1 150N
CI1 1 0 1.5P
CI2 2 0 1.5P
R1 1 3 162.5K
R2 3 2 162.5K
I1 4 50 1M
R3 99 5 651.7
R4 99 6 651.7
Q1 5 2 45 QX
Q2 6 7 46 QX
R43 45 4 600
R44 46 4 600
*Fp2=200 MHz
C4 5 6 6.1054E-13
I2 99 50 4M
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.335
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.155
EH 99 98 99 49 1
*Fp1=23.52 KHz
R5 98 9 1MEG
C3 98 9 6.7668P
*Fp=203 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 7.84E-16
*Fpcm=200 KHz
L2 98 17 795.77U
R13 17 16 1K
VA1 99 93 0
E1 93 23 99 15 1
R16 24 23 10
D5 26 24 DY
V6 26 22 .63V
R17 23 25 10
D6 25 27 DY
C9 23 22 500P
V7 22 27 .63V
V5 22 21 .63V
D4 21 15 DX
V4 20 22 .63V
D3 15 20 DX
L3 22 28 100P
RL3 22 28 100K
..ENDS
*LM6162 High Speed OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM6162 1 2 99 50 28
*Features:
*High bandwidth = 100MHz
IOS 2 1 150N
CI1 1 0 2P
CI2 2 0 2P
R1 1 3 90K
R2 3 2 90K
I1 4 50 1M
R3 99 5 351.7
R4 99 6 351.7
Q1 5 2 45 QX
Q2 6 7 46 QX
R43 45 4 300
R44 46 4 300
*Fp2=230 MHz
C4 5 6 9.8376E-13
I2 99 50 4M
EOS 7 1 POLY(1) 16 49 3E-3 1
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.43
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.23
EH 99 98 99 49 1
F1 9 98 POLY(1) VA1 0 0 0 .85
G1 98 9 POLY(1) 5 6 0 6.5E-3 0 8.646E-3
*Fp1=17.935 KHz
R5 98 9 1MEG
C3 98 9 8.874P
*Fp=230 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 6.9198E-16
*Fp=250 MHz
G5 98 18 15 49 1E-6
R15 98 18 1MEG
C6 98 18 6.3662E-16
*Fpcm=10 KHz
G4 98 16 3 49 1E-8
L2 98 17 15.915E-3
R13 17 16 1K
VA1 99 93 0
E1 93 23 99 18 1
R16 24 23 10
D5 26 24 DX
V6 26 22 .63V
R17 23 25 10
D6 25 27 DX
C9 23 22 200P
V7 22 27 .63V
V5 22 21 .23V
D4 21 18 DX
V4 20 22 .23V
D3 18 20 DX
L3 22 28 100P
RL3 22 28 100K
..MODEL QX NPN(BF=227.3)
..ENDS
*LM6164 High Speed OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM6164 1 2 99 50 28
*Features:
*High bandwidth = 175MHz
IOS 2 1 150N
CI1 1 0 3P
CI2 2 0 3P
R1 1 3 50K
R2 3 2 50K
I1 4 50 1M
R3 99 5 201.7
R4 99 6 201.7
Q1 5 2 45 QX
Q2 6 7 46 QX
R43 45 4 150
R44 46 4 150
*Fp2=190 MHz
C4 5 6 2.0765P
I2 99 50 4M
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.43
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.23
EH 99 98 99 49 1
F1 9 98 POLY(1) VA1 0 0 0 3.4
G1 98 9 POLY(1) 5 6 0 9.0E-3 0 10.6E-3
*Fp1=25.1 KHz
R5 98 9 1MEG
C3 98 9 6.3408P
*Fp=190 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 8.3766E-16
*Fp=203 MHz
G5 98 18 15 49 1E-6
R15 98 18 1MEG
C6 98 18 7.8401E-16
*Fpcm=3 KHz
G4 98 16 3 49 5.6234E-9
L2 98 17 53.052E-3
R13 17 16 1K
VA1 99 93 0
E1 93 23 99 18 1
R16 24 23 10
D5 26 24 DX
V6 26 22 .63V
R17 23 25 10
D6 25 27 DX
C9 23 22 500P
V7 22 27 .63V
V5 22 21 .23V
D4 21 18 DX
V4 20 22 .23V
D3 18 20 DX
L3 22 28 100P
RL3 22 28 100K
..MODEL QX NPN(BF=200)
..ENDS
*LM6165 High Speed OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM6165 1 2 99 50 28
*Features:
*High bandwidth = 725MHz
IOS 2 1 150N
CI1 1 0 6P
CI2 2 0 6P
R1 1 3 10K
R2 3 2 10K
I1 4 50 1M
R3 99 5 51.7
R4 99 6 51.7
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=120 MHz
C4 5 6 12.827P
I2 99 50 4M
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.43
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.23
EH 99 98 99 49 1
F1 9 98 POLY(2) VA1 VA3 0 0 0 0 0 0 4.25 0 0 4.978143E5
G1 98 9 POLY(1) 5 6 0 38.0E-3
*Fp1=25.1 KHz
R5 98 9 1MEG
VA3 9 11 0
C3 98 11 3.897P
*Fp=120 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 1.3263E-15
*Fp=124 MHz
G5 98 18 15 49 1E-6
R15 98 18 1MEG
C6 98 18 1.2835E-15
*Fpcm=10 KHz
G4 98 16 3 49 7.94328E-9
L2 98 17 15.915E-3
R13 17 16 1K
VA1 99 93 0
E1 93 23 99 18 1
R16 24 23 10
D5 26 24 DX
V6 26 22 .63V
R17 23 25 10
D6 25 27 DX
C9 23 22 500P
V7 22 27 .63V
V5 22 21 .25V
D4 21 18 DX
V4 20 22 .25V
D3 18 20 DX
L3 22 28 100P
RL3 22 28 100K
..ENDS
*LM6218/A Fast Settling Dual OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM6218 1 2 99 50 28
*Features:
IOS 2 1 20N
CI1 1 0 2.5P
CI2 2 0 2.5P
R1 1 3 3.125G
R2 3 2 3.125G
I1 99 4 40U
R43 45 4 1.25K
R44 46 4 1.25K
Q1 5 2 45 QX
Q2 6 7 46 QX
R3 50 5 2.54K
R4 50 6 2.54K
*Fp2=30 MHz
C4 5 6 1.0433P
I2 99 50 2.71M
R8 99 49 71.4K
R9 49 50 71.4K
V2 99 8 2.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.63
EH 99 98 99 49 1
*Fp1=38.24 Hz
R5 98 9 100MEG
C3 98 9 41.62P
*Fp=110 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 1.4469E-15
*Fpcm=6 KHz
G4 98 16 3 49 1E-8
L2 98 17 26.526M
R13 17 16 1K
E1 99 23 99 15 1
R16 24 23 10
D5 26 24 DY
V6 26 22 .63V
R17 23 25 10
D6 25 27 DY
C9 23 22 .001U
V7 22 27 .63V
V5 22 21 .63V
D4 21 15 DX
V4 20 22 .63V
D3 15 20 DX
L3 22 28 100P
RL3 22 28 100K
..ENDS
*LM6261 High Speed OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM6261 1 2 99 50 28
*Features:
IOS 2 1 150N
CI1 1 0 1.5P
CI2 2 0 1.5P
R1 1 3 162.5K
R2 3 2 162.5K
I1 4 50 1M
R3 99 5 651.7
R4 99 6 651.7
Q1 5 2 45 QX
Q2 6 7 46 QX
R43 45 4 600
R44 46 4 600
*Fp2=200 MHz
C4 5 6 6.1054E-13
I2 99 50 4M
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.335
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.155
EH 99 98 99 49 1
*Fp1=23.52 KHz
R5 98 9 1MEG
C3 98 9 6.7668P
*Fp=203 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 7.84E-16
*Fpcm=200 KHz
L2 98 17 795.77U
R13 17 16 1K
VA1 99 93 0
E1 93 23 99 15 1
R16 24 23 10
D5 26 24 DY
V6 26 22 .63V
R17 23 25 10
D6 25 27 DY
C9 23 22 500P
V7 22 27 .63V
V5 22 21 .63V
D4 21 15 DX
V4 20 22 .63V
D3 15 20 DX
L3 22 28 100P
RL3 22 28 100K
..ENDS
*LM6262 High Speed OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM6262 1 2 99 50 28
*Features:
IOS 2 1 150N
CI1 1 0 2P
CI2 2 0 2P
R1 1 3 90K
R2 3 2 90K
I1 4 50 1M
R3 99 5 351.7
R4 99 6 351.7
Q1 5 2 45 QX
Q2 6 7 46 QX
R43 45 4 300
R44 46 4 300
*Fp2=230 MHz
C4 5 6 9.8376E-13
I2 99 50 4M
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.43
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.23
EH 99 98 99 49 1
*Fp1=17.935 KHz
R5 98 9 1MEG
C3 98 9 8.874P
*Fp=230 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 6.9198E-16
*Fp=250 MHz
G5 98 18 15 49 1E-6
R15 98 18 1MEG
C6 98 18 6.3662E-16
*Fpcm=10 KHz
G4 98 16 3 49 1E-8
L2 98 17 15.915E-3
R13 17 16 1K
VA1 99 93 0
E1 93 23 99 18 1
R16 24 23 10
D5 26 24 DX
V6 26 22 .63V
R17 23 25 10
D6 25 27 DX
C9 23 22 200P
V7 22 27 .63V
V5 22 21 .23V
D4 21 18 DX
V4 20 22 .23V
D3 18 20 DX
L3 22 28 100P
RL3 22 28 100K
..ENDS
*LM6264 High Speed OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM6264 1 2 99 50 28
*Features:
IOS 2 1 150N
CI1 1 0 3P
CI2 2 0 3P
R1 1 3 50K
R2 3 2 50K
I1 4 50 1M
R3 99 5 201.7
R4 99 6 201.7
Q1 5 2 45 QX
Q2 6 7 46 QX
R43 45 4 150
R44 46 4 150
*Fp2=190 MHz
C4 5 6 2.0765P
I2 99 50 4M
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.43
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.23
EH 99 98 99 49 1
*Fp1=25.1 KHz
R5 98 9 1MEG
C3 98 9 6.3408P
*Fp=190 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 8.3766E-16
*Fp=203 MHz
G5 98 18 15 49 1E-6
R15 98 18 1MEG
C6 98 18 7.8401E-16
*Fpcm=3 KHz
L2 98 17 53.052E-3
R13 17 16 1K
VA1 99 93 0
E1 93 23 99 18 1
R16 24 23 10
D5 26 24 DX
V6 26 22 .63V
R17 23 25 10
D6 25 27 DX
C9 23 22 500P
V7 22 27 .63V
V5 22 21 .23V
D4 21 18 DX
V4 20 22 .23V
D3 18 20 DX
L3 22 28 100P
RL3 22 28 100K
..ENDS
*LM6265 High Speed OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM6265 1 2 99 50 28
*Features:
IOS 2 1 150N
CI1 1 0 6P
CI2 2 0 6P
R1 1 3 10K
R2 3 2 10K
I1 4 50 1M
R3 99 5 51.7
R4 99 6 51.7
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=120 MHz
C4 5 6 12.827P
I2 99 50 4M
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.43
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.23
EH 99 98 99 49 1
*Fp1=25.1 KHz
R5 98 9 1MEG
VA3 9 11 0
C3 98 11 3.897P
*Fp=120 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 1.3263E-15
*Fp=124 MHz
G5 98 18 15 49 1E-6
R15 98 18 1MEG
C6 98 18 1.2835E-15
*Fpcm=10 KHz
L2 98 17 15.915E-3
R13 17 16 1K
VA1 99 93 0
E1 93 23 99 18 1
R16 24 23 10
D5 26 24 DX
V6 26 22 .63V
R17 23 25 10
D6 25 27 DX
C9 23 22 500P
V7 22 27 .63V
V5 22 21 .25V
D4 21 18 DX
V4 20 22 .25V
D3 18 20 DX
L3 22 28 100P
RL3 22 28 100K
..ENDS
*LM6361 High Speed OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM6361 1 2 99 50 28
*Features:
IOS 2 1 150N
CI1 1 0 1.5P
CI2 2 0 1.5P
R1 1 3 162.5K
R2 3 2 162.5K
I1 4 50 1M
R3 99 5 651.7
R4 99 6 651.7
Q1 5 2 45 QX
Q2 6 7 46 QX
R43 45 4 600
R44 46 4 600
*Fp2=200 MHz
C4 5 6 6.1054E-13
I2 99 50 4M
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.335
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.155
EH 99 98 99 49 1
*Fp1=23.52 KHz
R5 98 9 1MEG
C3 98 9 6.7668P
*Fp=203 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 7.84E-16
*Fpcm=200 KHz
L2 98 17 795.77U
R13 17 16 1K
VA1 99 93 0
E1 93 23 99 15 1
R16 24 23 10
D5 26 24 DY
V6 26 22 .63V
R17 23 25 10
D6 25 27 DY
C9 23 22 500P
V7 22 27 .63V
V5 22 21 .63V
D4 21 15 DX
V4 20 22 .63V
D3 15 20 DX
L3 22 28 100P
RL3 22 28 100K
..ENDS
*LM6362 High Speed OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM6362 1 2 99 50 28
*Features:
IOS 2 1 150N
CI1 1 0 2P
CI2 2 0 2P
R1 1 3 90K
R2 3 2 90K
I1 4 50 1M
R3 99 5 351.7
R4 99 6 351.7
Q1 5 2 45 QX
Q2 6 7 46 QX
R43 45 4 300
R44 46 4 300
*Fp2=230 MHz
C4 5 6 9.8376E-13
I2 99 50 4M
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.43
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.23
EH 99 98 99 49 1
*Fp1=17.935 KHz
R5 98 9 1MEG
C3 98 9 8.874P
*Fp=230 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 6.9198E-16
*Fp=250 MHz
G5 98 18 15 49 1E-6
R15 98 18 1MEG
C6 98 18 6.3662E-16
*Fpcm=10 KHz
G4 98 16 3 49 1E-8
L2 98 17 15.915E-3
R13 17 16 1K
VA1 99 93 0
E1 93 23 99 18 1
R16 24 23 10
D5 26 24 DX
V6 26 22 .63V
R17 23 25 10
D6 25 27 DX
C9 23 22 200P
V7 22 27 .63V
V5 22 21 .23V
D4 21 18 DX
V4 20 22 .23V
D3 18 20 DX
L3 22 28 100P
RL3 22 28 100K
..ENDS
*LM6364 High Speed OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM6364 1 2 99 50 28
*Features:
IOS 2 1 150N
CI1 1 0 3P
CI2 2 0 3P
R1 1 3 50K
R2 3 2 50K
I1 4 50 1M
R3 99 5 201.7
R4 99 6 201.7
Q1 5 2 45 QX
Q2 6 7 46 QX
R43 45 4 150
R44 46 4 150
*Fp2=190 MHz
C4 5 6 2.0765P
I2 99 50 4M
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.43
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.23
EH 99 98 99 49 1
*Fp1=25.1 KHz
R5 98 9 1MEG
C3 98 9 6.3408P
*Fp=190 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 8.3766E-16
*Fp=203 MHz
G5 98 18 15 49 1E-6
R15 98 18 1MEG
C6 98 18 7.8401E-16
*Fpcm=3 KHz
L2 98 17 53.052E-3
R13 17 16 1K
VA1 99 93 0
E1 93 23 99 18 1
R16 24 23 10
D5 26 24 DX
V6 26 22 .63V
R17 23 25 10
D6 25 27 DX
C9 23 22 500P
V7 22 27 .63V
V5 22 21 .23V
D4 21 18 DX
V4 20 22 .23V
D3 18 20 DX
L3 22 28 100P
RL3 22 28 100K
..ENDS
*LM6365 High Speed OP-AMP MACRO-MODEL
* | inverting input
* | | | | output
..SUBCKT LM6365 1 2 99 50 28
*Features:
IOS 2 1 150N
CI1 1 0 6P
CI2 2 0 6P
R1 1 3 10K
R2 3 2 10K
I1 4 50 1M
R3 99 5 51.7
R4 99 6 51.7
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=120 MHz
C4 5 6 12.827P
I2 99 50 4M
R8 99 49 80K
R9 49 50 80K
V2 99 8 1.43
D1 9 8 DX
D2 10 9 DX
V3 10 50 2.23
EH 99 98 99 49 1
*Fp1=25.1 KHz
R5 98 9 1MEG
VA3 9 11 0
C3 98 11 3.897P
*Fp=120 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 1.3263E-15
*Fp=124 MHz
G5 98 18 15 49 1E-6
R15 98 18 1MEG
C6 98 18 1.2835E-15
*Fpcm=10 KHz
L2 98 17 15.915E-3
R13 17 16 1K
VA1 99 93 0
E1 93 23 99 18 1
R16 24 23 10
D5 26 24 DX
V6 26 22 .63V
R17 23 25 10
D6 25 27 DX
C9 23 22 500P
V7 22 27 .63V
V5 22 21 .25V
D4 21 18 DX
V4 20 22 .25V
D3 18 20 DX
L3 22 28 100P
RL3 22 28 100K
..ENDS
