Anyone knows this transistor?
Jenalee K.
A power transistor from the seventies in a TOP3 case with the following
printed on it:
line 1: "Texas Instruments logo" 8302
line 2: 3-453
It is used as a power transistor in a (dead) 5V power supply. A
datasheet or specs (Ic max) would be great.
Jenalee K.
Ancient_Hacker
printed on it:
line 2: 3-453
Jenalee K.
Well a 5V power supply isnt too critical an application-- you can
probably replace it with most any old TO-3 of the correct polarity.
Phil Allison
** Groper alert !
printed on it:
line 2: 3-453
** The " 8302 " code tells you it was made in the second week of 1983.
The other number is a private ID code applied for the benefit of maker of
the PSU.
** LOL - what an optimist.
The device is likely a TIP3055.
The TIP35 is another or even the TIP140 Darlington.
YOU need to figure out if it is NPN or PNP and a single transistor or
Darlington.
........ Phil
Jenalee K.
Phil Allison a écrit :
** Groper alert !
the PSU.
Darlington.
....... Phil
Thanks Phil, at least now I know that it was built somewhere in the
eighties. BTW, according to the schematics the transistor is PNP.
Jenalee K.
Phil Allison
"Jindalee K."
** Groper alert !
the PSU.
Darlington.
** So, if it IS a transistor and NOT a Darlington - the odds are very
high it's a TIP2955.
The TIP36 is a remote option.
Few other TIP numbers from the early 80s would qualify.
TIP2955s are still available - AFAIK.
....... Phil
