APC SU2200NET UPS Battery Backup repair
Korishan
Sep 2, 2015
10
Hello everyone.
I recently purchased the above UPS. I was able to get it to turn on, and test battery switching capability. It does work.
However, I decided to go ahead and take it apart and inspect my cheap investment (got it for $68 w/ free shipping). It is immaculately clean. Looking deeper on the main board, I noticed two darkened areas on the bottom of the pcb. I flipped it over to inspect and found 2 resisters were discolored.
Here's the link to my pics I've taken: http://tinyurl.com/pomb8bc
The two resisters are circled in yellow
The two resisters are the same color banding (though, it was very hard to make out the 3rd stripe) Brown Black Red Gold. I believe that makes these a 1k Ohms 5% Carbon Film. What I don't know is, the wattage of them. I did a band lookup on digikey.com and saw that there were several listings for these with varying wattages.
what I'm wondering is, are these resisters ok to use without any problems? The unit is old, and this is the only place I noticed any electronic wear/damage. Should I replace them? If so, what would be a recommended wattage rating?
Thanks for any help,
Korishan
Arouse1973
Adam
Dec 18, 2013
5,178
They look like 1/4 watt carbon film resistors. If you want to replace them then some metal film resistors are 0.5 watt for the same size. If the unit is working how it should then just leave it alone, it may go on for years. Dont fix what aint broke. You dont want to become what we call a Sunday Mechanic :)
Adam.
Korishan
Sep 2, 2015
10
Ok, thanks. I'll leave it in service as it is and see how well it works.
I don't have enough battery packs to do a load test on it yet. Found out it set up for 48 Volt battery pack.
Thanks again for your input.
Korishan
