Arcade game monitor problem
K
Ken G.
I have an old asteroids full size vintage video game .
I has a black & white monitor .
When it first comes on its fine . Within 10 minutes the whole image gets
bigger , things disappear off the edges . The center of the screen gets
a bit darker .
I suspected the hi voltage diode off the flyback and adjusting the hi
voltage pot but replacing that did not help .
I dont have any model #s the monitor has one medum circuit board and
one small board with the flyback in a metal box .
K
Ken Layton
rec.games.video.arcade.collecting is the correct newsgroup.
F
Franc Zabkar
a bit darker .
The "blooming" does sound to me like a low EHT problem. I'd check the
B+ going to the FBT, and the base drive to the LOP transistor. Make
sure the duty cycle doesn't change. I've seen this happen in an old
IBM monitor as a ceramic capacitor in the horizontal oscillator warmed
up. However, in my case the EHT gradually increased until the HV
protection shut down the monitor.
- Franc Zabkar
K
Ken G.
Thanks Franc .. I dont know which conection is B+ on this . It seems to
be a Wells Gardner monitor according to a website provided i an arcade
newsgroup .
F
Franc Zabkar
newsgroup .
I would think that one end of the primary winding would be connected
to the collector of the switching transistor, the other to the B+.
If the FBT has any part numbers, try locating a substitute here:
http://www.hrdiemen.es/products/index.php?command=viewSection&id=4&language=eng-GB
The HR substitute will have a wiring diagram with voltages.
I notice that the Wells Gardner Quadrascan colour monitor at the Atari
link provided by Dean uses a HV regulator circuit that senses a 180V
pulse from a tap on the primary winding and uses this feedback to vary
the B+ to the FBT, and thereby control the EHT.
- Franc Zabkar
Y
Yukio YANO
a bit darker .
Sounds to me, more like the Filament Voltage is dropping, cold solder
joint in filament circuit ?
This describes what happens to the image when I reduce the filament
Voltage on my Transmission Electron Microscope !
Yukio YANO
