Beachcomber
- Jan 1, 1970
- 0
My air-conditioner compressor stopped working the other day. It's a
240 V. 20 Amp Circuit with a (20 amp - dual pole) fused disconnect
outdoors at the unit and a dual=pole ganged 20 Amp circuit breaker
further upstream at the service entrance.
The AC tech found one of the 20 Amp fuses at the disconnect had
weakened and (after 7 years) had just opened up due to the inrush
current on the first attempt at operation for the season.
This got me to thinking. If someone less-experienced had opened up
the AC Compressor unit without removing the local disconnect, they
could have gotten a nasty shock (or worse) from the good fuse on the
other leg if they were grounded. (This is in the USA).
So I conclude that circuit breakers are safer than fuses (because the
poles are ganged). But wouldn't it be safer to have a pull out
disconnect at the compressor without the fuses, relying on the service
panel circuit breakers for overcurrent protection? Anyone know what
the code says on this?
I remember as a kid, all my dad's apartment buildings had dual-pole
fused disconnects for the 240 V. loads. I wonder if these were safe?
Beachcomber
Beachcomber
