Are there any dangers associated with ceramic coated reptile heating bulbs?
Voltaic
May 6, 2015
82
Are there any dangers with ceramic coated reptile heating bulbs when placed overhead as a heat lamp?
What is the exact frequency that the ceramic coating is converting the light into, is this a dangerous wavelength for your eyes? Does the fact that it is diffused over the whole ceramic coating make it less of an issue?
What would a completely safe distance be in case you looked at it?
kpatz
Feb 24, 2014
334
Those things produce more heat than light, they won't harm your eyes, any more than staring at a glowing electric stove burner will.
Voltaic
May 6, 2015
82
Ok thanks.
So are they giving off the same wavelength as a stove heater?
Tha fios agaibh
Aug 11, 2014
2,253
I don't know the wavelength, but I'd be concerned with the heat.
Make sure the lamp is nowhere near combustible materials, and the wiring to the fixture is rated for 90c.
Voltaic
May 6, 2015
82
OK thanks, I had planned to use it as an overhead heat lamp, do you think it would be effective or too far away to do much?
Tha fios agaibh
Aug 11, 2014
2,253
More of of a hvac question.
Lots of different factors come into play.
I will say electric heat is very inefficient.
Voltaic
May 6, 2015
82
Ok thanks, it's a shame I thought it would be efficient because it is coated with ceramic which I believed generated far infrared which was as fairly efficient heater, for water for example or anything composed mainly of water.
