Ashdown Bass amp
Phil Allison
** Hi,
I have an Ashdown ABM 200H with a burnt resistor on the power amp PCB.
Any know what value R10 is ?
You need a password to access schems on the company website.
BTW, all the mosfets have blown.
.... Phil
N
N_Cook
Arfa Daily said:
I have managed to get the occasional schematic out of them without a
password, by emailing technical direct. If you can convince them that you
are a bona fide engineer, rather than just an owner, they might help you out
as a one-off.
Arfa
same here. I think 3 different amps now - if you include issues found in
passing , not necessarily related to the symptoms /faults, that may help not
hinder.
Les Matthew
** Hi,
.... Phil
Don't know if this will help but on the ABM 300/500 output schematic R10
is 220R in the emitters of TR8 and TR9 (BF422) to V-.
Les.
Phil Allison
"Les Matthew"
** Sounds very like a probable value.
The burnt black remains measured 520 ohms.
.... Phil
N
N_Cook
Gareth Magennis said:
Same as a Trace AH500 I am repairing right now. 220R to both emitters of
BF422, (this one also burnt, reads 880R), collector to 15k to diode to 220R
to +V.
One of my Mosfets is blown.
Ashdown are Trace revisited I believe.
Gareth.
Isn't there a connection between Trace Elliot and Orange ?
Phil Allison
"Gareth Magennis"
Clive Button was the chief designer at Trace, I think. You often see his
name on the PCB's. You also find the initials B.L.T. on his stuff.
** BLT = bacon, lettuce and tomato ??
Phil, is there anything like that on the Ashdown PCB?
** The amp has gone back to its owner.
..... Phil
