asking about components
Gendiaaa
Feb 15, 2023
This ph meter module i fond someone share it but i do not understand what is pg item is the component that labeled 073100015 and also jp1 i think JP1 refers to jumper wires ?
bertus
3,882
It could well be that JP1 is only used for testing the Vguard voltage.
In normal operation JP1 should be open.
Bertus
dragon
Oct 31, 2022
248
you can pass current through a liquid, get the amps, and its like ph, its how conductive the water is, but how do you go from that to an electronic ph metre? what more is there to it, I cant really gather it from looking at the circuit by itself...
dragon
Oct 31, 2022
248
I see so its not the current, its the difference in voltages!!! so if i get a wire, from one solution to another, itll actually generate a tiny bit of current like how a hall sensor generates its tiny voltage?
